took butteryflys off, how do i take off the bar?
Old Apr 24, 2007 | 11:30 PM
j.dizzle
Guest
Posts: n/a
Default took butteryflys off, how do i take off the bar?
unscrewed the butterflys off my IM, how do i take off the lil bar that runs across it?
Old Apr 25, 2007 | 12:06 PM
j.dizzle
Guest
Posts: n/a
Default Re: took butteryflys off, how do i take off the bar? (boob)
Old Apr 25, 2007 | 12:09 PM
nonvteclude's Avatar
its either a screw or a c clip (i cant remember) that you take off from the outside the you pull them out.
Old Apr 25, 2007 | 12:11 PM
j.dizzle
Guest
Posts: n/a
Default Re: took butteryflys off, how do i take off the bar? (nonvteclude)
well on one side its like the spring like on the throttle body and the other side is just a solid looking peice
Old Apr 25, 2007 | 12:12 PM
ya knock that little cap off of that side and it should be a screw or clip
Old Apr 25, 2007 | 12:14 PM
j.dizzle
Guest
Posts: n/a
how do i knock it off? does the bar pull right out after that?
Old Apr 25, 2007 | 12:19 PM
pull it off with pliers or pry it off with a flat screw driver. then pull the other side out with some pliers or something like that.
Old Apr 25, 2007 | 12:21 PM
j.dizzle
Guest
Posts: n/a
doesnt seem like its coming off lol
Old Apr 25, 2007 | 03:35 PM
93h22a1vtec's Avatar
i just beat the **** out of mine and cut it up and it fell apart eventually
Old Apr 27, 2007 | 01:41 AM
j.dizzle
Guest
Posts: n/a
Old Apr 27, 2007 | 04:26 AM
flyrod's Avatar
Remove the TPS sensor, take the cable pulley off the other end, and the bar slides out where the TPS goes.
Old Apr 27, 2007 | 05:37 AM
Speedra500's Avatar
Default Re: took butteryflys off, how do i take off the bar? (flyrod)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flyrod &raquo;</TD></TR><TR><TD CLASS="quote">Remove the TPS sensor, take the cable pulley off the other end, and the bar slides out where the TPS goes. </TD></TR></TABLE>
I think he is wanting to remove the secondary IABs
Old Apr 28, 2007 | 02:42 PM
j.dizzle
Guest
Posts: n/a
Default Re: took butteryflys off, how do i take off the bar? (Speedra500)
just the bar that held the butterfly vavles, not the while plate. i already un-screwed all the butterflies off
Old May 3, 2007 | 05:20 AM
j.dizzle
Guest
Posts: n/a
Default Re: took butteryflys off, how do i take off the bar? (WARRIORS)
Old May 3, 2007 | 05:55 AM
mgags7's Avatar
I'm not exactly sure how that bar comes out, but I can tell you this, it would be much easier to just leave the plate out.
MelJ
Suspension & Brakes
Nov 7, 2010 11:48 AM
Mag00n
Honda Motorcycles
Apr 14, 2007 12:47 PM
david90
Apr 11, 2004 10:08 AM
illusion
Mar 10, 2003 11:43 AM
Suprdave
Jun 6, 2001 07:07 AM
