***obd1 conversion wiring problems HELP***
Old Apr 24, 2007 | 09:03 PM
HBK_DAVIDDD's Avatar
Default ***obd1 conversion wiring problems HELP***
ok so heres the deal... im swapping a obd1 d15b into a 1991 civic si(mpfi already). the motor is in, and most of the sensors are pluged up. obd0>obd1 conversion harness is pluged up with a p28 ecu, my main problem is how to wire up the sub harness i have 9 wires left but dont know where they go, and i cant seem to find any good resources online about this.
maybe someone can lead me to a good source, or lemme know where they go?!?!?
any help is appreciated!
Old Apr 24, 2007 | 10:01 PM
turbodcivic510's Avatar
if its a rywire harness. look at the instructions.
Old Apr 24, 2007 | 10:03 PM
RCautoworks's Avatar
Default Re: (turbodcivic510)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbodcivic510 &raquo;</TD></TR><TR><TD CLASS="quote">if its a rywire harness. look at the instructions.</TD></TR></TABLE>
Only if its a rywire harness, if its not, look at there instructions.
Old Apr 25, 2007 | 06:15 AM
Default Re: (RCautoworks)
I wish it would have came with some instructions.
Old Apr 25, 2007 | 06:30 AM
jedb18's Avatar
Default Re: (WAGOM4N)
what color are the 9 wires I can probably tell you where they go
Old Apr 25, 2007 | 06:46 AM
Disco Monkey's Avatar
Default Re: (jedb18)
most likely the wires are:
4 wires for a 4 wire O2 sensor
1 wire for Knock sensor
1 wire for VTEC Solenoid
1 wire for VTEC Pressure switch
1 wire for MIL (connect this wire to a ground with a switch between)
1 wire for IAB's (only for GSR manifolds)
you can find their location using this guide
http://www.ff-squad.com/technet/wiring.obd1.htm
Old Apr 25, 2007 | 07:34 AM
jedb18's Avatar
Default Re: (Disco Monkey)
here's what mine was
Blue-O2 sensor heater control(O2 BLK wire)
White-O2 sensor signal(O2 WHT wire)
Violet-VTEC solenoid signal
Gray-VTEC pressure switch signal
Green-Intake air bypass signal
Orange-Knock sensor signal
Red(2)-Power (IAB, O2 BLK wire)
Black(3)-Ground (SCS, VTM. O2 GRN wire)
Yellow-Service check signal
SoCal B18b 4dr
31
Apr 14, 2008 05:01 AM
99JdmDc2
Aug 16, 2007 07:43 AM
K-Drum
Jun 6, 2005 08:06 AM
B20-Rex
11
Dec 17, 2004 08:37 AM
jisu009
Mar 26, 2004 01:13 PM
