92 hatch Dx disk conversion **NEED HELP**
Old Apr 24, 2007 | 06:51 PM
slow_coupe05's Avatar
Default 92 hatch Dx disk conversion **NEED HELP**
Hi guys
Well this is my situation !!!!!!
i have a full front a rear disk set-up from a 96 acura integra Ls ... i am only doing this for looks not for performance ! ... Just an FYI
i need help
i have never done this i was told it was easy i have one problem tho just for the rear
what kind of brake line do i have in the rear is it metal or rubber like the front
is its metal what do i need to do to convert it to a rubber line .....that needs to go on cause of the integra !?!?
if its rubber i should not have a problem right ?!!?! ... staright botl on !?!?
Long shot but does anyone have the complete procedures for this swap i know that its done alot ! ... and its all the same basicly ! ... i;m kinda new here and dont know how to search very well !
Any help would be greatly apreciated ! ...
pictures would be awsome to ! ...
Old Apr 24, 2007 | 06:55 PM
Mr.EM1_EK's Avatar
Default Re: 92 hatch Dx disk conversion **NEED HELP** (slow_coupe05)
check the faq up top
Old Apr 24, 2007 | 08:51 PM
BlueIntegraBoy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slow_coupe05 &raquo;</TD></TR><TR><TD CLASS="quote">Hi guys
i need help
Rubber from the solid metal brake line to the caliper
Use rubber line that came with the swap
Unbolt anything you need connecting the knuckle to the suspension, and trailing arm from the frame
pictures would be awsome to ! ... </TD></TR></TABLE>
Old Apr 24, 2007 | 08:56 PM
uneek360's Avatar
i need help
lol...sorry to say but i really can't make out what your asking.
Old Apr 24, 2007 | 09:38 PM
hqrshw's Avatar
you will need the integras rubber brake lines. it would be nice if you upgrade to steel braided lines and run motul dot 4 brake fluid.
good luck man. its looks harder than it is.
if you need any help contact me @ hqrshw@sbcglobal.net
MoE JdM
Suspension & Brakes
Mar 27, 2008 10:48 AM
PARAZZI
Jul 4, 2005 12:12 AM
donivan
May 6, 2005 12:20 AM
hookedonvtec
Dec 13, 2004 11:59 PM
LSegHatchy
Nov 1, 2004 05:05 AM
