Full body kit and install price???
Old Apr 24, 2007 | 06:38 PM
maxlobes's Avatar
Default Full body kit and install price???
What would be a good estimate on getting a full body kit for a del sol and getting it professionally installed be?
Old Apr 24, 2007 | 06:42 PM
E-Rok's Avatar
EPIC TUNING
Default Re: Full body kit and install price??? (maxlobes)
$1,000,000
this is not the site to ask about body kits.
Old Apr 24, 2007 | 06:54 PM
harmonator84's Avatar
Default Re: Full body kit and install price??? (E-Rok)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by E-Rok &raquo;</TD></TR><TR><TD CLASS="quote">$1,000,000
this is not the site to ask about body kits.</TD></TR></TABLE>
Well where does he ask. People have asked alot worse on HT...Seems like Paint and Body would be the best section...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maxlobes &raquo;</TD></TR><TR><TD CLASS="quote">What would be a good estimate on getting a full body kit for a del sol and getting it professionally installed be?</TD></TR></TABLE>
To be honest with you not alot of bodyshops will touch a a bodykit. You can usually estimate it by taking whatever materials are and multiplying by 2. That will give you your total. Meaning whatever materials cost is usually the same it cost to have it installed(right). Just do some searching around. Ask all your local shops. Your best bet is installing it by yourself or with a friend that has done it before. Either way good luck.
Old Apr 25, 2007 | 07:59 AM
-NA-aLL-thE-wAy-'s Avatar
EFSS153
The best thing to do would be drive around to a few local body shops and get estimates. You likely won't get an accurate one on the i-net.
Old Apr 25, 2007 | 10:23 AM
Saga Boy's Avatar
Default Re: Full body kit and install price??? (-NA-aLL-thE-wAy-)
**** i'll do it for 200 reason why is if its not polyurethane or strong abs it will expletive up less than a month for a daily driver there fore u will be paying nonstop money for fiberglass and bodywork jus get a lip kit and slam ya ride papa u betta off!
Old Apr 25, 2007 | 03:10 PM
TheWhiteHatchProject's Avatar
Default Re: Full body kit and install price??? (Saga Boy)
when i had a xenon (which is urethane) kit put on my 02 civic to properly fit the kit with a set of z3 fenders it cost me 1500 for them to blend in the fenders to the side of the car as well as paint the kit, wing, and grill. you get what you pay for.
Old Apr 25, 2007 | 03:36 PM
LilWannabeJdm's Avatar
if u know how to remove you front and rear bumper then u all set to diy ....its not hard..just bolts and drill....u can do it even my little nephew can install it on my car with me on the side helping him..LOL
Old Apr 25, 2007 | 04:32 PM
Saga Boy's Avatar
Default Re: Full body kit and install price??? (TheWhiteHatchProject)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheWhiteHatchProject &raquo;</TD></TR><TR><TD CLASS="quote">when i had a xenon (which is urethane) kit put on my 02 civic to properly fit the kit with a set of z3 fenders it cost me 1500 for them to blend in the fenders to the side of the car as well as paint the kit, wing, and grill. you get what you pay for.</TD></TR></TABLE>your right u get what u pay for, luckily for me by trade i do autobody tech/custom paint etc.
Old Apr 26, 2007 | 01:43 PM
1uncleanDA's Avatar
DIY is the best route
Old Apr 26, 2007 | 07:59 PM
maxlobes's Avatar
Default Re: Full body kit and install price??? (1uncleanDA)
Im new to all this so, if I do it myself, all I have to do is screw some bolts on and ****?
Old Apr 27, 2007 | 06:56 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maxlobes &raquo;</TD></TR><TR><TD CLASS="quote">Im new to all this so, if I do it myself, all I have to do is screw some bolts on and ****? </TD></TR></TABLE>
If your new I wouldnt advise it. To do it right you have to revit/bolt them onto the car. The front/rear bumper is alittle easier because you mount them on the stock holes made for your bumpers. But the side skirts/door caps are alittle harder.
Also 99.9 percent of bodykits are not going to fit right and are going to take some modification to do.
Old Apr 27, 2007 | 11:04 AM
dinko's Avatar
Default Re: Full body kit and install price??? (harmonator)
DIY like all the other ricers...Zipties and duct tape DUHH!! I hope you got your 4" exhaust tip with it otherwise you wasted your monies!
jk
From what I've read theres a lot of prep that goes into a bodykit. The sanding and stuff...hell...even a used OEM bumper takes a couple hours to prep perfectly. Then there's paint...
it's definitely not gonna run ya cheap...not under a grand... at least if you want it "done right"
delsolnnewby
Jan 2, 2008 06:48 PM
DEL-SOL
12
Jul 9, 2007 08:44 PM
khhoa
24
Jun 28, 2007 12:43 AM
nolimitlowrider
May 24, 2006 03:48 PM
Blk Sol
Feb 10, 2006 07:17 AM
