Helpppppppppp
Old Apr 24, 2007 | 06:20 PM
jarven093's Avatar
Default Helpppppppppp
dose anyone know what it means when the oil light flickers when car is at idle ??? like coming to a stop it will flicker alittle bit but then will go away as soon as i touch the gas????? motor is a d16z6 93 ex civic
Old Apr 24, 2007 | 06:21 PM
Mikes2000civicsi's Avatar
Default Re: Helpppppppppp (jarven093)
oil changeeee timee
Old Apr 24, 2007 | 06:24 PM
jarven093's Avatar
Default Re: Helpppppppppp (Mikes2000civicsi)
is that all it means cause i just put new oil in ....i had a friend tell me its crank bearings but hes a muscel car guy any help some one???
Old Apr 24, 2007 | 06:38 PM
EG2Driver's Avatar
When i had my Mazda, the light would flicker because it barely had any oil in it, so there would not be enough oil pressure.
Maybe your pump is failing
Old Apr 24, 2007 | 06:41 PM
bmoua's Avatar
how much oil did you put it. I've got a y8 and i put in about 3 1/2 quarts. Check your oil stick bro...
Old Apr 24, 2007 | 07:35 PM
Vt3c_eg's Avatar
Default Re: (bmoua)
it means check your oil they're low!
Old Apr 24, 2007 | 07:37 PM
eg8tuner's Avatar
and if you have enough oil them your pump is gone of something is restricting your oil flow (spun bearing)
itzyaboyzeem03
Jul 1, 2016 04:40 PM
slow_low_eddie
Aug 20, 2014 07:04 PM
dagle
Apr 3, 2011 10:33 PM
JStar
Apr 6, 2006 02:29 PM
testing 1 2 3
May 3, 2003 05:56 AM
