Would i need to sleeve
Old Apr 24, 2007 | 05:42 PM
Mikes2000civicsi's Avatar
Default Would i need to sleeve
hi guys..i was going to put itr and new pistons in at the same time(11.5 compression)...i was wondering what the mm is for 2.0..i have a b18c1...would it make any noticeable diffrence and would i need to resleeve it before boring...thanks.
ps i searched
Old Apr 24, 2007 | 06:11 PM
doood's Avatar
been there done that
Default Re: Would i need to sleeve (Mikes2000civicsi)
to get 2L from a b18c you'll need 85mm. the only way to bore out this much is to resleeve first. max bore on stock sleeves is 82mm.
Old Apr 24, 2007 | 06:20 PM
Default Re: Would i need to sleeve (doood)
would 2.0 be worth it if i get nre pistons..figure if ima install new pistons might as well go 2.0...also later on can i turbo normally
Old Apr 24, 2007 | 06:33 PM
doood's Avatar
more displacement means potential for more power and torque. you decide if that's worth it to you.
hondacrx2
Oct 30, 2007 08:45 AM
gtowni3
Mar 8, 2005 09:47 AM
swlabhot
May 20, 2004 01:44 PM
B18 CYA
Apr 8, 2004 05:09 PM
Turbo_Si
Aug 13, 2002 09:12 PM
