DIY. re-wired fogs for DA's
got info from here: http://www.g2ic.com/forums/index.php
1. disconnect the black/ground wire from the battery..
2. pull out the fog light & defroster switches..
3. locate the fog light switch, now cut the --red & yellow-- wire about 2 inches away from the switch
(if the switches are located next to each other on the dash bezel, then skip to number 6. )
4. if the switches are away from each other, different sides of the dash bezel, then you need to get a wire, about a foot and a half long, single wire. some speaker wire would work fine also.
5. splice one end, so copper is exposed (using a knife or blade is fine, but i suggest using a wire stripper) then connect it to the --red & yellow-- wire of the fog light switch, your basically extended this wire.
6. now take the wire that is on the fog light switch. splice the end of it to expose the copper wire, and splice it in (connect it together) with the --black & yellow-- wire of the defogger switch..
7. do not cut the wire on the defogger switch, you are only cutting the housing, to expose the wire, so you can attach the --red & yellow-- wire with the --black & yellow-- wire..
so the wire will look like a " T " one wire running straight, with another wire attaching to it..
8. after you're done with that, put the switches back in place, connect the negative end on the battery, then your done
Old news...and I think this would belong in the Tech section.
Again...why you may ask?
Because I did this in 1999 when G2IC was an 8mm board.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Phil DeVtec »</TD></TR><TR><TD CLASS="quote">You avatar has nice boobies.
Agreed, post bigger pixxxx
</TD></TR></TABLE>Agreed, post bigger pixxxx
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Riced-EL »</TD></TR><TR><TD CLASS="quote">Agreed, post bigger pixxxx</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Thurman Merman »</TD></TR><TR><TD CLASS="quote">Just go search Svetlana from the real world. In fact, if you go to youtube, you can see the actual video of here ***** bouncing up and down
http://www.youtube.com/watch?v=ZyXzNAU0Pew
</TD></TR></TABLE>http://www.youtube.com/watch?v=ZyXzNAU0Pew
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Yellowone »</TD></TR><TR><TD CLASS="quote">
i went to high school with her. big bitch before, even bigger bitch after real world
. id still hit it though
</TD></TR></TABLE>i went to high school with her. big bitch before, even bigger bitch after real world
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4F CHR!S »</TD></TR><TR><TD CLASS="quote">
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Riced-EL »</TD></TR><TR><TD CLASS="quote"> i envy white ppl!!!!</TD></TR></TABLE>
Why?
I laugh at 'em
Why?
I laugh at 'em
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by negtegra. »</TD></TR><TR><TD CLASS="quote">
Why?
I laugh at 'em
Azn girls have no bodies thats why
Besides that proud Azn guy rite here...
Why?
I laugh at 'em
Neither do white girls.
</TD></TR></TABLE>Neither do white girls.
Neither do white girls.</TD></TR></TABLE>
White girls usually have nice *******...
White girls usually have nice *******...</TD></TR></TABLE>
If they're fat or their daddy bought them
</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Riced-EL »</TD></TR><TR><TD CLASS="quote">
White girls usually have nice *******...</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by negtegra. »</TD></TR><TR><TD CLASS="quote">
Neither do white girls.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Riced-EL »</TD></TR><TR><TD CLASS="quote">
Besides that proud Azn guy rite here...</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by negtegra. »</TD></TR><TR><TD CLASS="quote">
Why?
I laugh at 'em
keep it in the PM's
</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Riced-EL »</TD></TR><TR><TD CLASS="quote">White girls usually have nice *******...</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by negtegra. »</TD></TR><TR><TD CLASS="quote">
Why?
I laugh at 'em
keep it in the PM's
