A6 bottom with Z6 head and a Y8 head gasket is it safe with boost???
Old Apr 24, 2007 | 08:36 AM
Xemu's Avatar
Default A6 bottom with Z6 head and a Y8 head gasket is it safe with boost???
I have arp head studs I'm just worried about the compression with boost.Should I use a different gasket or am I safe???? Thanks
Old Apr 24, 2007 | 08:41 AM
CRX Toad's Avatar
Default Re: A6 bottom with Z6 head and a Y8 head gasket is it safe with boost??? (Xemu)
That will put you somewhere between 9-9.5:1 compression. How much boost are you running?
Old Apr 24, 2007 | 08:52 AM
Akiraboy's Avatar
http://www.zealautowerks.com, you can figure out your cr setup on their calculator.
Old Apr 24, 2007 | 09:01 AM
SIred91's Avatar
Rainman
Default Re: A6 bottom with Z6 head and a Y8 head gasket is it safe with boost??? (Akiraboy)
the guys in the hybrid forum or FI would prob be a bigger help than us doods....
Old Apr 24, 2007 | 09:37 AM
Xemu's Avatar
Default Re: A6 bottom with Z6 head and a Y8 head gasket is it safe with boost??? (CRX Toad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX Toad &raquo;</TD></TR><TR><TD CLASS="quote">That will put you somewhere between 9-9.5:1 compression. How much boost are you running?</TD></TR></TABLE>
I'll be running 8 psi......or I'd like to run 8psi.Should I go with a thicker gasket???
Old Apr 24, 2007 | 04:22 PM
Akiraboy's Avatar
depends on your setup, what are you using for control?
are using standard 75 mm pistons
std bore already?
is the head shaved or trimmed?
when you rebuild a head they shave a couple thousanths off to true it.
changes your cr besides the headgasket
what size turbo? what trim?
this thread will go in circles if you don't specify your setup fully
hop on this thread & read, chances are someone may already be runnin your setup
https://honda-tech.com/zerothread?id=1643764
gl
Red_ED8
Feb 23, 2008 09:13 AM
KansasKev
Feb 1, 2006 07:36 PM
menappi
Mar 27, 2005 12:47 PM
ELSpool
Dec 3, 2003 12:13 PM
