H22 in an SI... what is rev limit?
I got a 93 Si and I took out the H23 and swapped in a H22A1... its a USDM Vtec and I was wondering where the redline is on that motor and where the rev limiter is? Also im gettin a VTEC controller and I was wondering what a good spot to put Vtec would be?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ProjectTib »</TD></TR><TR><TD CLASS="quote">I got a 93 Si and I took out the H23 and swapped in a H22A1... its a USDM Vtec and I was wondering where the redline is on that motor and where the rev limiter is? Also im gettin a VTEC controller and I was wondering what a good spot to put Vtec would be?</TD></TR></TABLE>
H22 Redline is at 7400 RPM, and the rev limiter at 7800.
As far as the VTEC controller and the VTEC crossover point, my answer will always be as follows: Get it on a dyno!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ProjectTib »</TD></TR><TR><TD CLASS="quote">thank you but has anyone dynoed already and figured this out? all i have done is a intake/header/high-flow cat/exhaust</TD></TR></TABLE>
Different mods and different tuning make different power gains. You can't go by someone else's dyno results EVEN IF you have same/similar mods.
There are no shortcuts. Do it right or don't do it at all.
kingh90
Honda Civic (2006 - 2015)
11
Dec 30, 2008 07:54 PM
