Would bad suspension cause this?
I have a 95 civic EX. The suspension on it is worn out. When I go over bumps in the road the steering feels jittery. But the steering feels just fine the rest of the time.
I have new upper control arms and the bushing in the lower control arms look ok. So I was thinking I either need new new ball joints or new suspension. What do you think it would be?
could be bad shocks my car use to do that if i am thinking you have the same problem. i use to hit bumps and it felt like i was on a dirt road. but on a staight i was fine. i changed shocks and i was straight. good look!!
I had a similar problem in an old 88 Sentra. (yes Nissans are cool too)
When you'd ride over a bump it felt absolutely squirrely. Nuts on the freeway! It also felt like the car had power steering because the shocks were so soft.
I replaced the shocks and it was never a problem again. It also made the steering feel much tighter from then on. A friend drives it to this day, and it's still a little rocket.
When you'd ride over a bump it felt absolutely squirrely. Nuts on the freeway! It also felt like the car had power steering because the shocks were so soft.I replaced the shocks and it was never a problem again. It also made the steering feel much tighter from then on. A friend drives it to this day, and it's still a little rocket.
Jaynik
Dec 31, 2011 08:48 AM
