bouncing idle (searched)
Old Apr 24, 2007 | 06:10 AM
bboixtc's Avatar
Default bouncing idle (searched)
I have a 1992 SI 4WS AT
when i start my car, my idle will bounce up to 2k and after a while, it will level off back to normal.
This also happens when I put the car in park after driving.
Old Apr 24, 2007 | 06:13 AM
mgags7's Avatar
screw in the white screw in the back of the FITV
done
Old Apr 24, 2007 | 06:31 AM
bboixtc's Avatar
Default Re: (mgags7)
nub here. where is that located? does anyone have a pic of where it is? thanks again
Old Apr 24, 2007 | 06:37 AM
mgags7's Avatar
its the valve under the throttle body
search in the lude forum for the fast idle valve fix its around here somewhere....
Old Apr 24, 2007 | 06:49 AM
preludefien
Guest
Posts: n/a
lol yea...i just had the same prob and mgags helped fix it...under the left side of the throttle body attached my 3 10mm bolts.
mgags7's Avatar
Default Re: (preludefien)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by preludefien &raquo;</TD></TR><TR><TD CLASS="quote">lol yea...i just had the same prob and mgags helped fix it...under the left side of the throttle body attached my 3 10mm bolts.</TD></TR></TABLE>
word
Old Apr 24, 2007 | 07:19 AM
bboixtc's Avatar
is it easy to get to? like i don't have to detach anything?
do i do this while the car is running?
Old Apr 24, 2007 | 08:28 PM
bboixtc's Avatar
Default Re: (bboixtc)
Old Apr 25, 2007 | 06:37 PM
preludefien
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bboixtc &raquo;</TD></TR><TR><TD CLASS="quote">is it easy to get to? like i don't have to detach anything?
do i do this while the car is running?</TD></TR></TABLE>
lol dude no...while the car is off take it off screw it down and put it back on...and it your car is idles to high still screw take if off and screw in down further. if it is to low take it back off and screw its out a little...trial and error.
Old Jan 30, 2008 | 07:06 AM
bboixtc's Avatar
I did all that, my idle still bounces. When I remote start my car, you could here it pulsating.
Old Jan 30, 2008 | 09:38 AM
732xghost's Avatar
check and see if all vacuum lines are connected. and your IACV could be clogged.
magicguy
Jan 30, 2009 02:00 PM
jdmCivic925
Oct 25, 2005 02:37 PM
accordtuner96
Sep 14, 2004 05:42 AM
afterburners
May 9, 2004 04:37 AM
Spoonvtec
Nov 12, 2003 07:51 PM
