transmission questions
Old Apr 24, 2007 | 01:02 AM
3ViL_SI's Avatar
Default transmission questions
so i bought my 00 si about a month ago and the transmission detonated i have a hole right above my shift linkage in the clutch housing ..... would it be possible to mate a ls transmissions cluth housing to my transmission .. i know that the ls transmission will bolt up to my block but will the clutch housing be swappable and how hard would it be
Old Apr 24, 2007 | 01:53 AM
TurbdEG6's Avatar
Default Re: transmission questions (3ViL_SI)
how the hell do you detonate a transmission...i didn't even know that was possible
Old Apr 24, 2007 | 04:05 AM
perseverance's Avatar
ls tranny will bolt to ur b16... but it'll be pretty damn slow compared to a b16 tranny. clutch is interchangeable. basically everything is swappable from those transmissions. as long as ur not installing a cable tranny u shouldn't have a problem. while you're at it tho.. get urself a new flywheel or get ur flywheel resurfaced.
Old Apr 24, 2007 | 02:34 PM
3ViL_SI's Avatar
Default Re: transmission questions (TurbdEG6)
its possible and very damn annoying and it happened on the way to work shifting out of first
Old Apr 24, 2007 | 02:48 PM
smileycvc's Avatar
yes it will work just make sure you put everything back toghether right.
Old Apr 24, 2007 | 02:54 PM
doood's Avatar
been there done that
Default Re: transmission questions (smileycvc)
a tranny isnt going to "detonate" unless it was severely abused
Old Apr 24, 2007 | 03:04 PM
93eg2james's Avatar
Default Re: transmission questions (doood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doood &raquo;</TD></TR><TR><TD CLASS="quote">a tranny isnt going to "detonate" unless it was severely abused</TD></TR></TABLE>
x2.
Everything is interchangable with any 94-01 Integra tranny. GL. Be a little more careful shifting next time. Remember, completely depress the clutch before shifting
i.e.
Old Apr 24, 2007 | 03:39 PM
3ViL_SI's Avatar
Default Re: transmission questions (93eg2james)
had the car less than a month ive got pics of the damage and will try and post later tonight .......... but yeah i can see where the severly abused part comes in
Old Apr 24, 2007 | 03:48 PM
thehatchninja's Avatar
it's probably from not changing the fluid, or not having enough fluid. I can see wearing out syncros and sleeves from "abusive" driving, but this sounds like a lack of maintanance....which is a form of abuse i suppose.
I would not suggest putting an LS transmission, the B16 gearing is the best thing going for the 99-00 Si's.
Old Apr 24, 2007 | 05:14 PM
3ViL_SI's Avatar
Default Re: (thehatchninja)
i really dont want to use the ls transmission just the clutch housing off of one i just hope it fits to my transmission so i can use the stock trans. with a ls clutch housing
Old Apr 24, 2007 | 07:01 PM
93eg2james's Avatar
Default Re: (3ViL_SI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 3ViL_SI &raquo;</TD></TR><TR><TD CLASS="quote">i really dont want to use the ls transmission just the clutch housing off of one i just hope it fits to my transmission so i can use the stock trans. with a ls clutch housing</TD></TR></TABLE>
It will work. No need to worry. Do you think you're going to use the gears ect from your b16 trans in this housing? If you blew a hole in your trans, I'd suggest not using it again in a different case.
Old Apr 24, 2007 | 07:32 PM
3ViL_SI's Avatar
Default Re: (93eg2james)
im hoping to use my gears yes i mean it still goes into gear it just has no pressure all the fluid is gone and as i said theres a hole in the clutch housing and its due to a crack found that out tonight i dont want to switch the eniter transmission housing just the cluth housings
Old Apr 24, 2007 | 07:33 PM
crzyracer1706's Avatar
Default honda civic dx 00 D series engine
can i use 5 speed mt tranny 92 to 00 will fix on my engine?
Old Apr 24, 2007 | 07:38 PM
Default Re: honda civic dx 00 D series engine (crzyracer1706)
are ya ll guy there???
Old Apr 24, 2007 | 07:42 PM
SkepTicZ's Avatar
hmmm
Old Apr 24, 2007 | 07:44 PM
93eg2james's Avatar
oooh okay, nvm I missed this. I thought you blew a hole threw the trans with a part of a gear or something. If that were the case then, I wouldn't use ANYTHING from the old tranny.
If you just had a crack or something, then you might be okay. My only concern would be that if you ran those gears dry for any length of time, that you would have had some chafing and grinding. If you ran the trans dry for any length of time, I would seriously consider replacing the trans.
Old Apr 24, 2007 | 08:09 PM
doood's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crzyracer1706 &raquo;</TD></TR><TR><TD CLASS="quote">can i use 5 speed mt tranny 92 to 00 will fix on my engine?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crzyracer1706 &raquo;</TD></TR><TR><TD CLASS="quote">are ya ll guy there??? </TD></TR></TABLE>
start your own damn thread and ask a coherent question
Old Apr 24, 2007 | 08:44 PM
ridin98civic's Avatar
Default Re:
so the clutch blew up? if the clutch housing cracked it shouldnt allow the tranny fluid to leak out.
Old Apr 24, 2007 | 09:56 PM
3ViL_SI's Avatar
Default Re: Re: (ridin98civic)
yeah the clutch housing is the only thing fucked up like i said i have pics but there on my girlfriends phone and ill show the hole and crack thats in the housing.... so its just my clutch housing not the whole transmission it still shifts in to gear and everything and right after it happened its been sitting not moved ive been waiting on a transmission
Old Apr 25, 2007 | 10:29 AM
93eg2james's Avatar
Default Re: Re: (3ViL_SI)
Okay, well lets answer this question once in for all.
YES. You can use the clutch housing off an LS case with your trans. The cases are identical.
GL!
Old Apr 25, 2007 | 11:22 AM
The LS clutch housing will be fine. I had previously assumed that the problem was within the gear section of the transmission. I would guess that the problem was due to an improperly installed clutch.
When you crack the cases apart you will be able to tell if the gears are destroyed or not. Theres a magnet in there that you should empty....it will have shavings in it ALWAYS...however if it has larger chucks of metal stuck to it you might have a problem.
Good luck
Old Apr 25, 2007 | 06:23 PM
3ViL_SI's Avatar
I just wanna say to all those that have helped big props you guys just saved me a butt load of money
chadwick16
Feb 24, 2005 01:09 PM
TeGGY_LS
May 16, 2004 10:36 AM
hatchattak
Feb 11, 2004 05:24 AM
SiR831
Jun 4, 2003 09:04 PM
ThatRicerDaniel
Oct 7, 2002 10:59 PM
