fuse keeps blowing after battery swap
Old Apr 23, 2007 | 08:53 PM
rhd_ef8's Avatar
Default fuse keeps blowing after battery swap
I just put an Optima Yellow Top in my CRX and the 70A battery fuse keeps blowing, (3) times now. It blew the first time hooking up the battery. We changed it out and as soon as the screw touched it it blew again. Thinking it might have been the order we screwed the fuse down, we tried again battery side first, when the screw touched the fuse box side again it blew. Any one else have this problem??? Solutions???
Old Apr 23, 2007 | 09:49 PM
rhd_ef8's Avatar
Default Re: fuse keeps blowing after battery swap (rhd_ef8)
anybody?
Old Apr 23, 2007 | 10:02 PM
black88si's Avatar
do you have the positive and negative terminals hooked up backwards?
Old Apr 24, 2007 | 05:39 AM
rhd_ef8's Avatar
Default Re: fuse keeps blowing after battery swap (black88si)
bump
Old Apr 24, 2007 | 06:21 AM
Akiraboy's Avatar
there have been some circumstances where the terminals on the battery have been mismarked, this happened to 2 people I know using Optimas.
I'd recommend using a Multimeter to confirm the batterys' true polarity.
Old Apr 24, 2007 | 10:41 AM
rice a roni's Avatar
yah i'd say check polarities...
put your old one back in and see what happens.
Old Apr 24, 2007 | 10:10 PM
rhd_ef8's Avatar
Default Re: fuse keeps blowing after battery swap (rice a roni)
problem solved......polarity
Old Apr 27, 2007 | 05:37 AM
Akiraboy's Avatar
good to hear!
Old Apr 27, 2007 | 05:41 AM
crxdxsir's Avatar
Default Re: (Akiraboy)
wow , that is very handy info. i woulda never guessed that they would mark the tops wrong.
Old Apr 28, 2007 | 01:28 PM
flipsyde's Avatar
wow... someone should contact the company and let them know.
Old Apr 28, 2007 | 01:30 PM
crxdxsir's Avatar
Default Re: (flipsyde)
where is the quality control guy?!?!
Old Apr 28, 2007 | 01:32 PM
flipsyde's Avatar
Default Re: (crxdxsir)
haha... fire his *** for not catching this problem.
Old Apr 29, 2007 | 11:27 AM
Akiraboy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxdxsir &raquo;</TD></TR><TR><TD CLASS="quote">where is the quality control guy?!?!</TD></TR></TABLE>
In China
Believe it or not, its a common prob with domestic & import batteries, I'm kinda curious as to why this problem is recurring as well.
Personally, I believe they don't give a ****.
Need to report them to the US DOT & to your local states attorney. If there are enough complaints they will be forced to make changes.
http://www.optimabatteries.com
click U.S., then contact and bitch your head off!!!
odyssey 07
Mar 13, 2018 11:00 PM
mtg
Nov 29, 2009 07:44 AM
seamus657
Mar 6, 2009 08:47 PM
DiSbaDbOi
16
Jan 5, 2005 07:24 PM
