B18C wiring info.
Old Apr 23, 2007 | 05:58 PM
iceman7329's Avatar
Default B18C wiring info.
Im going to be swapping a JDM B18C type R 98+ into my 94 LX soon. The engine includes the engine harness and ECU. I need to know what it is going to take to get this wired up and running. Ive been reading and searching for the last 2 days and cant come up with anything. I assume adding a clutch pedal to my car should be as simple as getting my parts from a donor car and bolting them in correct?
Old Apr 23, 2007 | 06:04 PM
builthatch's Avatar
MiG-21 superfan
Default Re: B18C wiring info. (iceman7329)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iceman7329 &raquo;</TD></TR><TR><TD CLASS="quote">Im going to be swapping a JDM B18C type R 98+ into my 94 LX soon. The engine includes the engine harness and ECU. I need to know what it is going to take to get this wired up and running. Ive been reading and searching for the last 2 days and cant come up with anything. I assume adding a clutch pedal to my car should be as simple as getting my parts from a donor car and bolting them in correct?</TD></TR></TABLE>
did you check the hybrid forum?
Old Apr 23, 2007 | 06:13 PM
iceman7329's Avatar
Default Re: B18C wiring info. (builthatch)
Yes, but I cant find a definite 100% answer.
Old Apr 25, 2007 | 06:08 PM
iceman7329's Avatar
So no one can take the 30 seconds to give me a link considering I cant find the answer myself?
Old Apr 25, 2007 | 06:28 PM
ekb16's Avatar
your saying you can find anything on a gsr swap into a eg? WOW!!!you must of been lookin in the wrong place for the past 2 days then...newayz you would use your stock harness and modify that to fit the motor ...since the motor is obd2 and your car is obd1, ur gonna need a p28 and chip that or get a obd1 p72 which is for a gsr...
Old Apr 25, 2007 | 06:34 PM
iceman7329's Avatar
Default Re: (ekb16)
I cant find anything about how to wire it correctly, maybe Im a ******* dumbass I dont know. But what I REALLY have to ******* know is what will have to be modified. I CANNOT have this car off the road more than 2 days. Im ready to say the hell with honda and go back to fords/chevy.
What does all this eg/ek bullshit mean? Ive never known that.
Old Apr 25, 2007 | 07:02 PM
builthatch's Avatar
MiG-21 superfan
Default Re: (iceman7329)
y0 jerk, i had my fiance time me...it took 46 seconds for me to find this-
http://www.c-speedracing.com/h...p.php
where? 6 posts down in one of 4 stickied threads at the top of the HYBRID forum
to you and your fuckln attitude.
EDIT: found this too with a total of two search tries-
https://honda-tech.com/zerothread?id=1255332
go to search, type in "auto manual" in the query box, select the search forum as 'hybrid', select 'search titles', select 'archived' in the upper right and hit SEARCHHHHHHH
you will have a billion threads about the auto to manual swap.
Modified by builthatch at 11:13 PM 4/25/2007
Old Apr 25, 2007 | 07:05 PM
ekb16's Avatar
if your motor was out of the car then it would be really easy...Get a wireing diagram for the motor and your car
STEP1: Sit both motors side-by-side with both harness still on the motors
STEP2: On your stock motor lable all the sensors and u unplug them 1 at a time until you have the whole engine harness of your stock motor
STEP3: Find all the sensors and locate them on your GSR
STEP4: Take your stock harness that has all the lables on it and start pluggin it up to the GSR. If they dont reach, tare off the black covering and try to free up some wire instead of cutting and extending.
STEP5: Cover back up the wireing with the same black cover and new black electrical tape.
STEP6: Now for the sensors that you dont have a plug for, find a plug on your GSR harness that fits the sensor, cut it off, solder a long wire(s) to it, plug it on the sensor, blend it into the stock harness and run it thru the firewall to your ecu location
STEP7: find a ecu wireing diagram and pin the extra sensors that you added like Knock sensor, Vtec etc..
STEP8: double check everything is hooked up, connections are good, drop it in and you should be good to go
STEP9: run open headers in your neighborhood and let the neighbors call the cops on u
Old Apr 25, 2007 | 07:12 PM
iceman7329's Avatar
Default Re: (ekb16)
Awsome thanks. Both of you. The ECU is in the trunk of this car right?
Old Apr 25, 2007 | 07:17 PM
ekb16's Avatar
ROFLMAO
are you serious? believe it or not the ecu on your honda is on the passengerside bottom kick panel
Old Apr 25, 2007 | 07:18 PM
iceman7329's Avatar
Default Re: (ekb16)
Thats what I had always thought until I pulled the carpet out of the trunk and saw what looked like it on the right side. But I didnt look at it close enough to tell, didnt care at the time.
Hayden_Fourroux
Feb 2, 2016 09:01 PM
ITRICED
Feb 19, 2008 04:10 PM
Mr. Giggles
Sep 27, 2006 09:37 PM
illuzi0nz
Jul 31, 2005 09:22 AM
KRS
Aug 27, 2003 07:58 PM
