Need an O2 sensor wiring guru....
Old Apr 23, 2007 | 04:22 PM
EGJason's Avatar
Default LAF Sensor wire in a p06 ECU?
I've recently swapped a VX engine (D15z) into my EG coupe just to get it running for a bit while I wait for another swap.
Well, my problem is finding the source on the engine harness to connect the second black wire (+12v) to. The D15B didn't use pin A25, but A25 on the ecu does have a wire going into the engine bay, just havn't been able to find where yet. The HELM manual has come up shorter than a handicap bus for once on this. Or I'm just lost in diagrams lately haha
The O2 sensor plug from the VX has:
| wht | blk |
| grn | blk |
Row 1
white --> primary heated o2 signal (D14 on ECU)
blk --> o2 sensor heating element (A6 on ECU)
Row 2
grn --> sensor ground (D22 on ECU)
blk --> A25 or any +12v power source????
The D15B harness plug:
| yel / blk | blk | grn / wht | wht |
| (empty) | wht/blu | org/blue | org |
Row 1
yel / blk --> o2 sensor heating element (A6)
blk --> PGI Ground < 1 volt (A23)
grn / wht --> sensor ground (D22)
wht --> knock sensor
Row 2
empty --> self explanitory
wht/blu --> empty?
org/blue --> o2 sensor heating signal (D14)
org --> VREF (not used)
I've got D22, D14 and A6 wired up just fine. It's just this last wire....
Modified by EGJason at 7:25 PM 4/28/2007
Old Apr 23, 2007 | 04:34 PM
EGJason's Avatar
Default Re: LAF Sensor wire in a p06 ECU? (EGJason)
bump for changes.....I explained it wrong the first time.....sorry
Old Apr 28, 2007 | 06:22 PM
EGJason's Avatar
bump again!
1992cxcivicEG
Dec 18, 2009 07:42 AM
DALE-EK4
40
May 3, 2007 11:41 AM
dturbo
Jul 26, 2005 03:17 AM
dturbo
Jun 8, 2005 06:16 PM
