Continuing issue with leakage.
Old Apr 23, 2007 | 04:11 PM
foomashoo's Avatar
Default Continuing issue with leakage.
Hey guys,
I've posted here before, and although it was helpful, I'm still having the same problem:
I have a '98 EX Coupe, and the trunk has an issue with bad leakage when it rains. Every time it rains I have to drain the trunk, and it prevents me from ever putting anything in the trunk. I was advised to crawl into the trunk with a flashlight and have someone spray it down while I watched for the leak. I did this, however, I was unable to pinpoint anything.
So I'm wondering if anyone else here has had this problem, and how they fixed it. Or if anyone else has an advice as to where the location of this leak might be. Any help is appreciated. Thanks
-Ethan
Old Apr 23, 2007 | 04:49 PM
foomashoo's Avatar
Default Re: Continuing issue with leakage. (foomashoo)
Anyone?
Old Apr 23, 2007 | 05:17 PM
92ehatch's Avatar
did you check the sunroof drains? i believe they are lines that run out the trunk.
if you have a sunroof. otherwise keep looking
Old Apr 23, 2007 | 08:22 PM
foomashoo's Avatar
Default Re: Continuing issue with leakage. (92ehatch)
I do have a sunroof, and I checked them (at least what I thought was them, two large plastic tubes running through the body out drain holes on each side of the trunk). I ran water on top of my car over the sunroof and nothing came through them, they don't look clogged or anything either. I can't figure out for the life of me where this water is getting in. I checked my tail lights as well... Anyone else have any suggestions?
Old Apr 23, 2007 | 08:42 PM
foomashoo's Avatar
Nevermind guys, I found it. After obsessing over it and searching for every possible source I found it's the air vent on the driver side of the trunk not sealing properly. It's letting quite a bit of water in...
ReVeNgEd-SoN
Aug 25, 2011 05:58 PM
91EFCIVICII
Feb 28, 2011 11:56 AM
671islander
Paint and Body
Jan 3, 2010 12:37 AM
foomashoo
Mar 20, 2007 12:02 AM
wonton2049
11
Dec 11, 2005 05:21 PM
