Problem after valve lash
Old Apr 23, 2007 | 03:21 PM
Boostedb20EH2's Avatar
Default Problem after valve lash
My car has been surging from 1 to 2 rpms and i checked all obvious signs fitv iacv and vaccum. Someone suggested valve lash adjustment.. Even though my friend sean adjusted them 2 months ago,i knew they were still bad and they have a tick to them. I decided to do this one myself. I first checked cylinder 1. Then went to adjust 3 to tdc and found one that seemed pretty loose. I decided i got in over my head, put everything back together and started up the car. It not idles really rough and the smell of gas is pretty strong. Tell me what i did wrong and how to fix it
Old Apr 23, 2007 | 03:41 PM
Default Re: Problem after valve lash (Boostedb20EH2)
Alright to restate.. I adjusted one intake from cylinder 3, couldnt exactly get it right. Adjusted it to what i thought was close and said to hell with it and gave up.
Old Apr 23, 2007 | 03:53 PM
h2point2's Avatar
may sound dumb but check your coolant level
Old Apr 23, 2007 | 03:56 PM
Default Re: (h2point2)
What does that have to do with anything? It ran fine before i f'd with it.
Old Apr 23, 2007 | 04:16 PM
h2point2's Avatar
your iacv will do that idle up and down if your coolant is low
Old Apr 23, 2007 | 04:18 PM
Well right now my problem is the valve lash. I obviously did something wrong..
Old Apr 23, 2007 | 04:19 PM
Default Re: (Boostedb20EH2)
One the one that i adjusted.. I just tried to readjust it and i can get feeler .003 to drag... I dont get it...
Old Apr 23, 2007 | 04:44 PM
Update. Rechecked specs,put on valve cover.. Started it,idles rough for 2 seconds and died. Im thinking spark plugs now? Anyone confirm?
Old Apr 23, 2007 | 05:22 PM
STI champstar's Avatar
OK make sure your car is COLD when you adjust the valves. I think that might be your problem. No one adjusts the valves when the car has ran. The car has to be sitting over night before you touch em.
Old Apr 23, 2007 | 05:24 PM
Default Re: (STI champstar)
I adjusted them after the car sat for 3 hours
Old Apr 23, 2007 | 06:11 PM
builthatch's Avatar
MiG-21 superfan
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostedb20EH2 &raquo;</TD></TR><TR><TD CLASS="quote">I adjusted them after the car sat for 3 hours</TD></TR></TABLE>
not long enough. it's gotta sit overnight,
and what specs are you using?
remember, the adjustment order is
1342
so, with the cam gear "0" or up mark up, you can adjust intake and exhaust of the first cylinder. turn the crank so the cam gear turns a 1/4 turn, then do the int and ex for 3, and so on and on...
check this link for details- http://www.redpepperracing.com....html
Luca
Sep 21, 2010 11:24 AM
HybridBB6
Jun 24, 2007 02:36 PM
accordisslow
Jan 22, 2006 08:27 PM
redex94
Mar 22, 2005 10:28 AM
WuShu
Nov 30, 2001 11:48 PM
