What are you guys running suspension wise?
I just want to see what other Ef'ers are running as far as suspension mods
My setup is:
KYB AGX struts
Arospeed lowering springs
Wicked rear camber kit
Ebay adjustable upper ball joint/arm
Front and rear Strut bars
And
14" 89 Crx Si wheels
My setup is:
KYB AGX struts
And
91 CRX SI
Koni Yellows
Ground Control Coils
Stock Swaybars
JK Motorsports traction Bar
Stock Si wheels
and I have a ES bushing kit i will eventually install...
Koni Yellows
Stock Swaybars
Stock Si wheels
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jspek_Rex »</TD></TR><TR><TD CLASS="quote">
Revo Tech. Upper LCA</TD></TR></TABLE>
upper LCA?!?!
you mean camber links?
upper LCA?!?!
koni yellows/gc coilovers w/ top hats 400f/500r <--this weekend
ES bushings<-- soon
stock si swaybars
innovative front crossmember with poly bushings
15" meshies.
i'll let you know how the ground controls feel
ES bushings<-- soon
stock si swaybars
15" meshies.
91 crx si
k sport coil overs
prothane bushings all around and prothane endlinks
88 lca's
si wheels
falken rt615's
havent driven on it since im waiting for my motor but it looks nicer then my tokico strut intrax spring combo did
k sport coil overs
88 lca's
si wheels
falken rt615's
omni street coilovers I believe (were on car when I bought it) rides nicely.
suspension techniques 22 mm rear sway bar.
crx hf front sway bar.
no name tie bars front and rear.
last car I was running Tein RA's for an ITR (the car had shot bushings everywhere) and it rode like crap. I'm guessing it was because of my lack of bushing material in between things though.
progress cs-2 coilovers
r-1 camber kit in front
homemade camber kit in rear
e-bay strut bars all around upper and lower
stock si sway bars
handles great smooth ride but it does get down when i want to
stock si sway bars
