RC51 riders- need help
Old Apr 23, 2007 | 02:10 PM
green98civic's Avatar
Default RC51 riders- need help
Yesterday i was riding on the beltway doing about 90 in 5th gear when the bike all of sudden hipcupped and the my speed want down to 75. as i was pulling off to the side of the beltway, the bike began chugging and jerky me forward. i have a motorcycle mechanic friend who was riding and she had no idea, she has the same bike. so we decided to get back on the belway-nothing happned. went to a cousins house and was heading home when it did it again. all of sudden the rpms went from 5,000 to 0 then 0 to 5000rpms. Once again chugging and jerking me around. the FI light was coming on at the same time when all this was happening. finally we get to her house and the bike could barely stay at 1500 to idle. you could hear it chugging and gasping for fuel or air. and the FI was going on and off.
i had a full tank of gas in the bike. this doesnt happen in turns or twisty road, it happnened on the beltway.
what do u think is wrong?
does honda have a box that they can plug in,like a car, to read the codes? eventhough the light is coming on and off?
thanks guys. MIKE
Old Apr 23, 2007 | 02:24 PM
knockout's Avatar
Default Re: RC51 riders- need help (green98civic)
do you have a manual? usually the FI light blinks in sequences that will tell you the problem.
Old Apr 23, 2007 | 03:00 PM
Jasper_db1's Avatar
Do you have a power commander?
Old Apr 23, 2007 | 03:09 PM
rdblckSV650S's Avatar
Default Re: RC51 riders- need help (Jasper_db1)
I bet you have a PCII.
And i would assume if your FI light is going off that you have an FI problem. If you have a manual, check the blink code. If not, check rc51.com
Old Apr 23, 2007 | 03:14 PM
.RJ's Avatar
.RJ
Bad tank of gas. The RC's are real sensitive to that, for some reason or another - this happened to me twice when I owned mine.
Drain the tank, and refill with new gas and it will go away.
Phucking shitboxes.
Old Apr 23, 2007 | 03:22 PM
Jasper_db1's Avatar
Default Re: RC51 riders- need help (.RJ)
Yours must have been a lemon!
Old Apr 23, 2007 | 03:29 PM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jasper_db1 &raquo;</TD></TR><TR><TD CLASS="quote">Yours must have been a lemon!</TD></TR></TABLE>
My RC was a total piece of ****. Every time i see one I want to go kick it out of spite.
The F4i is faster, handles better and a lot easier to ride. expletive a RC.
Old Apr 23, 2007 | 04:04 PM
there is no power commander. bike is compeltely stock. i will check the manual tonight.
after it happened the first time. i filled up after i left my cousins house with a new tank of gas. i dont know
Old Apr 23, 2007 | 04:06 PM
should i take it to the dealership? maybe a bad sensor or injector?
the guy i bought it from. had it sitting in his garage for a long time.
thanks guys for everything keep me the post coming for insight. before i have to make a dreaded trip to the dealership
Old Apr 23, 2007 | 04:16 PM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by green98civic &raquo;</TD></TR><TR><TD CLASS="quote">before i have to make a dreaded trip to the dealership </TD></TR></TABLE>
I told you what to do, you dont have to go to the dealer.
Old Apr 23, 2007 | 04:19 PM
EngineNoO9's Avatar
I &lt;3 my RC. though mine coughed and hiccuped on me but it was cause I didn't lock tite the battery terminals. the positive lead came off and it was all types of fucked until I put it back on.
Old Apr 24, 2007 | 07:09 AM
backlash's Avatar
Default Re: RC51 riders- need help (knockout)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by knockout &raquo;</TD></TR><TR><TD CLASS="quote">do you have a manual? usually the FI light blinks in sequences that will tell you the problem.</TD></TR></TABLE>
Yep. Count the number of times the FI light blinks, once you know this number, you can look it up and it will tell you exactly what the problem is.
I have the service manual burned to a CD at home. Let me know the code and I can look it up for you if you don't have a manual.
Old Apr 24, 2007 | 10:17 AM
.RJ's Avatar
.RJ
Default Re: RC51 riders- need help (backlash)
If the FI light goes out when the sputtering stops, there wont be any stored codes.
Old Apr 24, 2007 | 10:12 PM
Phoenix1's Avatar
Sounds like a loose battery connection, double check them.
Old Apr 25, 2007 | 07:46 AM
RA062424's Avatar
Default Re: (Phoenix1)
I think if the battery connections are loose the bike would just die, that's what mine did.
Old Apr 25, 2007 | 08:43 AM
.RJ's Avatar
.RJ
Default Re: (rseaburgh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rseaburgh &raquo;</TD></TR><TR><TD CLASS="quote">I think if the battery connections are loose the bike would just die</TD></TR></TABLE>
And it wouldnt restart.... the battery on the RC is way too small for a big twin, IMHO.
Add that to my list of gripes
Old Apr 25, 2007 | 08:48 AM
.paul's Avatar
it is like a bad ex girlfriend
Old Apr 27, 2007 | 03:32 AM
Default Re: (.paul)
going to take a look at the bike this weekend to check for the battery connections. i will let you guys know. Blacklasd i pmed you.
Old Apr 27, 2007 | 03:34 AM
.RJ's Avatar
.RJ
Default Re: (green98civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by green98civic &raquo;</TD></TR><TR><TD CLASS="quote">going to take a look at the bike this weekend to check for the battery connections.</TD></TR></TABLE>
Uhm... ok... have fun with that. Bring tools to lift up the gas tank and drain it too. Only takes about 10 minutes.
Old Apr 27, 2007 | 04:54 AM
...rohit's Avatar
Default Re: (.paul)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .paul &raquo;</TD></TR><TR><TD CLASS="quote">it is like a bad ex girlfriend</TD></TR></TABLE>thud
Old Apr 29, 2007 | 05:00 PM
Default Re: (...rohit)
checked the battery today and the connections were fine. it is kinda hard to count the number of times the fi light comes on when you are on the beltway slowing down and trying to get off to the shoulder.
maybe fuel filter or injector?
what should i do next?
Old Apr 29, 2007 | 05:02 PM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by green98civic &raquo;</TD></TR><TR><TD CLASS="quote">what should i do next?</TD></TR></TABLE>
Are you ******* kidding me? READ!
Old Apr 29, 2007 | 05:10 PM
Default Re: (.RJ)
sorry. i am draining the tank tomorrow.
Old May 6, 2007 | 04:37 AM
Drained the tank, put dry gas in, and added new gas to it. ran fine. had it idle for 5 mins to get the FI light to come on and also opened the throttle up. once again the light never came back on.
the old gas we took out. nothing out of the usual, no water and no dirt.
havent gotten to ride the beltway or street, was at work, but the mechanic this should take care of it.
what do u you guys think? should i take it to the dealer tomorrow or just cancel and wait to see if it happens again?
Old May 6, 2007 | 08:19 AM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by green98civic &raquo;</TD></TR><TR><TD CLASS="quote">what do u you guys think? should i take it to the dealer tomorrow or just cancel and wait to see if it happens again?</TD></TR></TABLE>
If you havent ridden it yet, how do you know if it needs to go to the shop?
