91 honda crx no signal to injectors help
Old Apr 23, 2007 | 01:02 PM
miguel_aka_timon's Avatar
Default 91 honda crx no signal to injectors help
theres no signal to my injectors to open ppl tell me it could be my ECU wut do ya'll think ?
Old Apr 25, 2007 | 10:06 PM
Old Apr 26, 2007 | 07:17 AM
mahatma's Avatar
Default Re: (miguel_aka_timon)
did this just happen randomly? what have you done to the car recently?
Old Apr 27, 2007 | 11:39 AM
Default Re: (mahatma)
yeah it happen randomly well i thougt it wuz my distributor so i changed the cap,rotor,spark plugs and wires so its sparkin and gas is flowin cuz my pump is good and my filter is basicly new. then i tested the injector conections with a test light but nothin no signal to my injectors to open.
Old Apr 27, 2007 | 12:22 PM
mahatma's Avatar
i'm a n00b when it comes to electrical, but i wonder if a test light would pick up on injector pulse.....i thought it was a bunch of on/off sequences, very rapid...?
are you sure you're getting fuel to the rail in that case?
and also you can't assume the spark is there because you changed cap, rotor, plugs & wires
seems like anytime i had trouble with spark, it was always something more expensive than those things LOL
Old Apr 27, 2007 | 02:11 PM
Perfectionist's Avatar
Default Re: 91 honda crx no signal to injectors help (miguel_aka_timon)
One side of the injector clips should have voltage on them (only when the ignition is first turned to run and while the CEL is lit, and again once the distrubutor signals the ECU the engine is turning.). The volts come from the main relay. The ECU completes the circuit path to ground to trigger the injectors as required.
Old Apr 27, 2007 | 10:43 PM
black dahlia's Avatar
check the resistor box for your injectors with the test light or a multimeter
Old Apr 27, 2007 | 11:11 PM
civic_jdm16's Avatar
Default Re: (black dahlia)
Icm little box in the distributor. I have so many problems with those things, on almost ever car I had !!!!!
P.S. Don't buy one from (Advance Auto Parts & Batteries)
(Advance Auto Farts & Tragities)
Old May 3, 2007 | 08:08 AM
Default Re: (civic_jdm16)
Thanks for the help. It turned out that my relay did not work......it sounded like it had sand or somethin in it...lol
B16Civic93
Jan 20, 2014 04:30 PM
anon191
17
Jun 25, 2013 10:33 AM
davesrex
Jun 12, 2007 08:43 PM
OrangeBoost
May 30, 2006 10:22 AM
