changed dx to si dizzy now no start???
Old Apr 23, 2007 | 12:27 PM
beatthisspeed69's Avatar
Default changed dx to si dizzy now no start???
i depinned the wires on the si plug and put the dx plugs on the si dizzy and now i have no start...it is still dpfi so is that y or should it still start with the si dizzy even though its dpfi???
Old Apr 23, 2007 | 12:31 PM
bump.need to know asap. n e body?
Old Apr 23, 2007 | 12:38 PM
19992civichatch's Avatar
u need ur dx dizzy the si is ment for mpfi and it gives out more pulses or something
Old Apr 23, 2007 | 01:39 PM
si it wont start like that..ha ha good thing im doing the conversion today lol
Old Apr 23, 2007 | 03:33 PM
janz3n's Avatar
Default Re: (beatthisspeed69)
why would you put a si distributor on a dpfi engine?did the dx one crap out? if so iv tried the same thing and it wont work without the mpfi swap
Old Apr 23, 2007 | 08:06 PM
blinger's Avatar
Default Re: (janz3n)
yea man, the Si wont work on the DX. Trade it for another DX or something. I'm sure someone will want it.
Old Apr 23, 2007 | 08:31 PM
N2HIFI's Avatar
Default Re: (blinger)
you need a pm6 ecu to run a si dizzy
chris
Old Apr 23, 2007 | 08:35 PM
Default Re: (N2HIFI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by N2HIFI &raquo;</TD></TR><TR><TD CLASS="quote">you need a pm6 ecu to run a si dizzy
chris</TD></TR></TABLE>
will a pr4 ecu be cool im doing a mpfi swap so i need the si dizzy
Old Apr 23, 2007 | 08:48 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beatthisspeed69 &raquo;</TD></TR><TR><TD CLASS="quote">
will a pr4 ecu be cool im doing a mpfi swap so i need the si dizzy</TD></TR></TABLE>
bump
Old Apr 24, 2007 | 03:23 AM
janz3n's Avatar
i dont know, i dont think so. most mpfi write ups has all this info for you though.
Old Apr 24, 2007 | 07:47 AM
crxnj's Avatar
obd0 pr4 will,yes..You already have the si distributor now do the mpfi conversion wiring and be done with it
Old Apr 24, 2007 | 09:05 AM
already did most of the mpfi conversion just need to wire up the resistor box and hopefully itll start right up no problems....thnx for all the info guys much appreciated
Old Apr 25, 2007 | 05:53 AM
blinger's Avatar
make sure all the connections on the ecu are nice and tight. I had a problem for over 2 months with the MPFI swap, turned out to be loose connections with the wires coming into the ecu and the ecu pins
Old May 5, 2007 | 01:34 PM
janz3n's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blinger &raquo;</TD></TR><TR><TD CLASS="quote">make sure all the connections on the ecu are nice and tight. I had a problem for over 2 months with the MPFI swap, turned out to be loose connections with the wires coming into the ecu and the ecu pins</TD></TR></TABLE>
glad to hear im not the only one that this happened to. mine was only a month though.
jb0705
Jul 9, 2006 09:49 PM
xvracing
Sep 9, 2003 08:23 PM
tangledwebster
Oct 5, 2002 11:37 AM
simike
Aug 13, 2002 02:50 PM
Red_Si
Jul 5, 2002 04:57 AM
