Testing waters for Turbo Project part out
Testing Waters
94 Integra LS Vin available by request
98-01 front bumper headlights rear bumper tail lights
ITR front lip, oem rear lip kit, oem side kit , itr replica spoiler
needs body work...and paint...radiator support needs to be welded on..needs windshield
engine
LS block
Darton sleeved 84mm
cp pistons
pauter rods
z10 block girdle
moroso pickup and pan
itr oil pump (endyn modified)
itr water pump
ARP main studs
AEBS Head Studs
Cyldiner head
GE LS/vtec kit
JDM ITR CYLINDER HEAD- ported + polished by Headgames motorworks
ferrea valves 3angle valve job
ferrea springs + retainers
jdm itr cams
edelbrock victor X intake manifold
STR 68mm TB
AEM fuel rail
SX FPR
1000cc injectors
Turbo kit
Full-race Top mount kit
T4 turbine Gt35r
4" down pipe w/ 4" electronic cut out --routed to a 3" thermal exhaust
Driveline
GSR trans w/ Quaife lsd
Tilton Cerametalic twin disc clutch/machined oem flywheel
tilton hydrolic TO bearing kit
Gator stage 3? axles with upgraded prodrive hubs
Miscllaneous
JDM itr rear sway bar w/ ASR brace
Tein flex suspension
energy suspension bushings
Skunk2 camber plates
Rota slipstreams 15x7
Mickey Thompson ET streets approx 26" tall
fuel cell -8 -10 lines
corbeau seats
electronic boost controller
aem wideband
miscellaneous gauges
SX fuel pump+ filter
PWR half radiator
few other things that im forgetting off hand..id liek to sell the car as hole..but i will part out if theres enough interest...
All these parts are new...car ran (IDLE) for 10 minutes ... I just dont have the cash to finish this project...my loss is your gain
LOW ***** WILL BE IGNORED
Modified by TurBoTeG at 6:55 PM 4/23/2007
engine
LS block
Darton sleeved 84mm
cp pistons
pauter rods
z10 block girdle
itr water pump
ARP main studs
AEBS Head Studs
Cyldiner head
GE LS/vtec kit
jdm itr cams
STR 68mm TB
AEM fuel rail
SX FPR
1000cc injectors
Turbo kit
T4 turbine Gt35r
Driveline
Miscllaneous
corbeau seats
aem wideband
PWR half radiator
-faded-
Mar 22, 2008 04:24 AM
tim_adams85
44
Mar 3, 2007 03:20 PM
DC2 to AP2
May 16, 2006 07:20 AM
