CEL - OBD0
https://honda-tech.com/zerothread?id=468260 The FAQ is your friend for future reference.
That code is for a bad VSS signal. If your speedo is functioning properly, try resetting the ECU and see if it goes away. I used to get a ghost code 17 on my DOHC ZC swap from time to time even though everything worked properly.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trevdawg »</TD></TR><TR><TD CLASS="quote">well i got in an accident and then got my car back and the speedo doesn't work at all but all the other gauges do but i will try to reset the computer</TD></TR></TABLE>
If your speedo doesn't work you need to replace the speedo cable before the code goes away. Or maybe it just became dislodged when the accident occurred and you need to push it back in.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wiZCo »</TD></TR><TR><TD CLASS="quote">
Or maybe it just became dislodged when the accident occurred and you need to push it back in.</TD></TR></TABLE> most probable
dthug
Aug 17, 2006 11:29 AM
ATS*Mark
Dec 8, 2004 06:13 PM
