how to remove gauge cluster?
what car? usually, remove the 2 screws from the top of your instrument panel, once those screws are out, pull from the bottom straight out, held in by clips. once the outer housing is removed, there are 4 screws holding the cluster in place. unscews those and unplug your cluster from behind. once it is removed, push in all the plastic tabs around the cluster and pull the plastic face off. then unscrew your stock gauges off and replace them.
SC2.2CL
Mar 29, 2006 11:03 AM
