95 civic turn signals and cluster
My turn signal and speedometer bith stopped working. I open the steering colum and took out the switch for the turn signals, seems to be working and i get continuity all the way to the lights. The turn signal colors going into the switch are green/yellow and green/blue and a blue/greene for power i think. Does anyone know what color they are coming out of the firewall. thoes colors are not coming out. Also any ideas why the would both stop working.
also a little more info, everything on the gauge went out. Gas gauge, speedometer, odometer, and tac. even the temp gauge. Also at the same time, will sitting at a red light, the turn signals went out. All at the same time. But the flashers still work.
the fuse in the fuse panel under the dassh had a fuse that said backup, well it also control the gauges, also disconnected the VSS plug and sprade WD40 in the connector. as far as the turn signals, i had to go from the switch and create a new block with there own flasher and then run them to the to lights. Works like a champ.
Yahoo sn chuck417
Yahoo sn chuck417
this link that BlueIntegraBoy provided is great, break down all fuse, thanks to him i got it working. going to have to send him a beer. link below
94-01 Integra/96-00 Civic Cluster Into 92-00 Civic Wiring Diagrams (rev. 1/07)
Jay.D.Em!
Apr 17, 2006 07:17 PM
STPREZ
Jan 18, 2005 06:10 PM
