No start
Old Apr 23, 2007 | 08:39 AM
TurboEK9Coupe's Avatar
Default No start
Just finished up my engine re-build and went to crank it up and theirs nothing. The fuel pump wont turn on and the starter wont engage to turn the motor over. I have checked every fuse and tripple checked all of the connections. i went to hook up a scan tool and it says "link error". I had a built motor in there before. I took my motor out to fix a leaking head gasket and did some more upgrades to the bottom end. And i also painted the engine bay and had some brackets powder coated. Thats all I did different this time. I went to check for fuel leaks and thats when i discovered the communication problems with the car. Its acting like the computer is not pluged in and when i try to start it the radiator fan comes on. Any advise or help would be greatly appericaited. Thanks
Old Apr 23, 2007 | 11:02 AM
93egsir's Avatar
check for power and ground at the ecu. main relay could cause this but cheaper to check grounds. the one on the t-stat housing is what stopped my car from running this weekend after I re-installed my engine.
Old Apr 23, 2007 | 07:54 PM
Default Re: (93egsir)
Yea i got it running. I forgot to put the ground wire from the frame rail to the trans. One little wire and it wont start. I had a fresh set of eyes look at it for me. But now that its running it has no power. I hit the gas and its slower than a single cam non VTEC in a heavy *** car. Im thinking that i need to check the timing again or something. Thanks for the help
Old Apr 24, 2007 | 04:43 AM
93egsir's Avatar
if the car runs ok and isnt makign any type of horrible noise than I would check cam timing first.
JdmRex805
19
Nov 20, 2014 05:23 PM
whasian
11
Nov 7, 2013 02:53 AM
drshottest718
Mar 26, 2007 03:47 PM
1hottEG6
May 8, 2002 06:47 AM
1hottEG6
May 7, 2002 02:17 PM
