what kind of primary battery for a 1000 watt RMS system?
I am putting a pretty decent but modest system back in my car and am wondering what the best battery to use would be. I will also have a carputer and a little extra neon lighting. I would like to get a red top to match my black and red color scheme, but optima says they are a starting battery and only meant for 400 watt and less systems. How about Interstate? I am willing to spend up to $125, but would like to stay black in color. Any recommendations?
i dont think your gonna find much in that price range. check out http://www.kinetikaudio.com
i am running a 1360 watt rms system and use a duralast gold battery from autozone and a "big 3" upgrade. i have had this for about 2 months and see no problems or stress with my battery or charging system. unless you want to listen to your stereo while the car is off, stick to a normal battery.
i've got a hc1400 with stock alt with 1000w RMS to my sub and 300w RMS to my speakers and my volts hardly ever drop down lower then 14.0v
u asked about battery... go with an optima yellow top. if u have a weak battery, i wouldn't suggest killing it with a powerful amp. now what type of car do u have? don't go with a reg battery or even an optima red... only optima yellow. they're designed for serious audio applications. if u need more info on why.. i'm sure u can read up on optima's website. i had a brochure somewhere in my toolbox. on the last fiberglass trunk we build.. we installed 3 yellow tops and a high powered alternator. that was for 4 solobaric 12" L7's, two kicker 1000.1 and one eclipse 4ch. never had any problems.
I went ahead and got an 800 cca interstate for now at least. $90. it is actually for my '91 300zx twin turbo. i killed the alternator with the system last time and that was without the 200 watt 2 channel amp. i think the old alternator was on it's way out anyway, but when the motor is dropped to install the new upgraded turbos maybe i'll get an HO alternator too.
Bbasso
Audio / Security / Video
36
Nov 25, 2003 11:46 AM
94
