WetSanding / Wet Sand
can someone please give me a walkthrough on how to wet sand please...do you use soak the car and paper with water and slightly sand away or is there more to it??any techniques??type of paper u guy use?..and thanks in advance...
there is wet/dry sand paper. Its usually black with a yellow/tan back to it and will say wet/dry on it.
Keep the paper and the surface wet. You can use a spray bottle to wet the surface, or a bucket of water to dip the paper in. when your sanding make sure to keep the paper wet enough so it doesn't get that "froth" buildup.
