Megan Racing Lower H Brace
As you drive your car undergoes stress as your whole chassis will twist and absorb a lot of energy created by the force of inertia and gravity. Over the years, it s been proven that a performance vehicle must reinforce the chassis and make a more rigid frame by connecting points in your vehicle that are crucial to the behavior of your vehicle.
By connecting points in your chassis and reinforcing the frame you are able to channel that energy that is being absorbed by the chassis flex back into your suspension components. This allows your suspension components such as your springs, shocks, and swaybars to do their job more effectively with more stability.
An H-Brace connects the underside of your chassis and frame by connecting 4 crucial points underneath your chassis that undergo the most stress during cornering. Proffesional installation is HIGHLY recommended due to the familiarity of the connections between the chassis and subframes.
Please note that some ground clearance will be compromised; however this is often no greater than 2" and is often directly under the front wheels.
Order here: <FONT COLOR="blue">Megan Racing Lower H Brace</FONT>
Modified by prostreetonline at 8:16 PM 5/1/2007
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HvRRZ »</TD></TR><TR><TD CLASS="quote">what is the difference between the sb-hbb and the sb-sbr?</TD></TR></TABLE>
HBB is Blue, HBR is red
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blakh »</TD></TR><TR><TD CLASS="quote">do they fit del sols?
bash away, if this is a stupid question...</TD></TR></TABLE>
yep, just get the one for the 92-00 civic
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr poo »</TD></TR><TR><TD CLASS="quote">why is pro installation HIGHLY recommended? its not just a bolt on affair?</TD></TR></TABLE>
As long as you are familiar with your vehicle and working on cars, you will be fine
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blakh »</TD></TR><TR><TD CLASS="quote">how bad does this affect clearance, and is it worth the sacrifice??</TD></TR></TABLE>
If your car is super slammed, this might not be for you.
Most race race/autox setups aren't low enough to not be able to use this h-brace.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blakh »</TD></TR><TR><TD CLASS="quote">well for $50 i might as well get it... </TD></TR></TABLE>
It's a good price. The H brace is also very light, not heavy like some others
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMCRX »</TD></TR><TR><TD CLASS="quote">Any pics of it mounted on the 92-00 civic?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by inspyral »</TD></TR><TR><TD CLASS="quote">How's cat clearance on the 92-00 Civic piece? I had problems with the H-Brace I had before hitting my stock cat, and it looks like the exact same design.</TD></TR></TABLE>
I'd like to know cat clearance as well!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lockheedload »</TD></TR><TR><TD CLASS="quote">
I'd like to know cat clearance as well!</TD></TR></TABLE>
Megan says it will fit, and we had not had clearance problems
CivicWagonRUS
16
Oct 23, 2008 01:41 PM
