ILcrxsi1's turbo D build(56k, get some lunch)
Old Apr 22, 2007 | 01:29 PM
ILcrxsi1's Avatar
I tell doctors what to do
Default ILcrxsi1's turbo D build(56k, get some lunch)
I finally get to make my own build thread. This is my first turbo project ever and the first turbo car I've ever owned, so I'm excited as hell. But, because this is the first time I've done this feel free to point it out to me when I'm ******* up. The pics I took today are blurry as hell. I will get more soon though.
I would like to say thanks to the people that have helped my out with this so far:
Rcautoworks, for cutting the hell out of my car to fit in a half size radiator and making my manifold, downpipe, and dumptube.
Autoworks for making my charge pipes and supplying the intercooler
stealthmode for the oil line kit
Dave(suprdave) at the whip factory for tuning
and 90JPRCRX for helping my out with **** and taking pictures
Anyway here is What the car looked like when I got it.
Here is what it looks like now after new paint, a jdm d15b, new suspension, and a shitload of other parts that I don't feel like listing.
First thing I did was put on the cold side pipes and mount up the intercooler.
You can see my half size radiator in this pic. Thanks Rcautoworks
This is how I mounted the intercooler. I basically cut holes in the front of the bumper support and drilled holes in the bottom so that I could put bolts through. Add some washers and you're done. It's pretty ghetto, but it's sturdy. It's also a little off center because I didn't measure very well.
Next I put in the DSM 450's. I don't know if I'm lucky or stupid, but mine went right in without having to open up the holes in the o-rings.
And here is my turbo and manifold, oh wait I'm still waiting for Bob at Rcautowoks to finish the manifold and downpipe
This is the D15b and si trans we are throwing in 90JPRCRX's car
And this is a link to my catch can setup
https://honda-tech.com/zerothread?id=1917722
Modified by ILcrxsi1 at 9:38 PM 6/19/2007
Old Apr 22, 2007 | 01:46 PM
ILcrxsi1's Avatar
Default Re: ILcrxsi1's turbo D build(56k, get some lunch) (ILcrxsi1)
And yes those are worm style clamps, but they're smooth on the inside so that they don't cut in to the couplers. Since I'm only running a .5 bar spring I think they will be just fine.
Old Apr 22, 2007 | 02:05 PM
90JPRCRX's Avatar
Smells like Tuna
those pictures suck, wheres the ones i took
edit
like this teaser
Old Apr 22, 2007 | 02:06 PM
abnaasefmb's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ILcrxsi1 &raquo;</TD></TR><TR><TD CLASS="quote">And yes those are worm style clamps, but they're smooth on the inside so that they don't cut in to the couplers. Since I'm only running a .5 bar spring I think they will be just fine.</TD></TR></TABLE>
either they will or they wont. tbolt clams don't cost too much but you might be ok. also check behind the endtanks and make sure there are not any bolts on the frame that might rub a hole into your FMIC. what i do id put some windoweld on the backs of the end tanks just to make sure they don't hit the fram or rub. looking good so fare. if you engine is out go ahead and paint the engine bay.
Old Apr 22, 2007 | 02:07 PM
stealthmode62's Avatar
Default Re: ILcrxsi1's turbo D build(56k, get some lunch) (90JPRCRX)
What a difference. Good job.
Old Apr 22, 2007 | 02:11 PM
RCautoworks's Avatar
Default Re: ILcrxsi1's turbo D build(56k, get some lunch) (stealthmode62)
Log manifold is done, just need to mock up the downpipe
Looking good so far, car is super clean in person, atleast I thought so.
ILcrxsi1's Avatar
Default Re: ILcrxsi1's turbo D build(56k, get some lunch) (abnaasefmb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by abnaasefmb &raquo;</TD></TR><TR><TD CLASS="quote">
either they will or they wont. tbolt clams don't cost too much but you might be ok. also check behind the endtanks and make sure there are not any bolts on the frame that might rub a hole into your FMIC. what i do id put some windoweld on the backs of the end tanks just to make sure they don't hit the fram or rub. looking good so fare. if you engine is out go ahead and paint the engine bay. </TD></TR></TABLE>I already made sure that it isn't touching anywhere. That isn't my engine though
Old Apr 22, 2007 | 02:14 PM
ILcrxsi1's Avatar
Good camera pics
Old Apr 22, 2007 | 02:45 PM
brandoom's Avatar
An Hero
Im a little jealous.
Nice car. Hooray for turbo!
Do you have a daily? Thats whats really ******* up my wanna be build.
That and money. And a lack of garage.... I fail ay life
Old Apr 22, 2007 | 02:52 PM
ILcrxsi1's Avatar
Default Re: ILcrxsi1's turbo D build(56k, get some lunch) (brandoom)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brandoom &raquo;</TD></TR><TR><TD CLASS="quote">Im a little jealous.
That and money. And a lack of garage.... I fail ay life </TD></TR></TABLE>Lack of a daily driver and garage have stopped me from doing this in the past. I have an 06 scion tc for my daily now and I moved into a house with a garage over the winter. I bought a nice *** air compressor when I moved too. If those things wouldn't have happened, then I wouldn't even be doing this now.
Old Apr 22, 2007 | 03:48 PM
STREETWERKZ's Avatar
ballin' *** spoolin' ***!
Old Apr 22, 2007 | 06:05 PM
Autoworks's Avatar
Default Re: ILcrxsi1's turbo D build(56k, get some lunch) (STREETWERKZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STREETWERKZ &raquo;</TD></TR><TR><TD CLASS="quote">ballin' *** spoolin' ***! </TD></TR></TABLE>
Looks good
I like this pic
Old Apr 22, 2007 | 06:19 PM
Default Re: ILcrxsi1's turbo D build(56k, get some lunch) (Autoworks)
FYI, charge pipes and positive battery terminals don't like each other.
Old Apr 22, 2007 | 06:25 PM
harmonator84's Avatar
Looks like some crazy rust on that driver door...did you swap doors or patch the rust?
Old Apr 22, 2007 | 08:34 PM
ILcrxsi1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stealthmode62 &raquo;</TD></TR><TR><TD CLASS="quote">FYI, charge pipes and positive battery terminals don't like each other. </TD></TR></TABLE>Yeah, I know. That charge pipe is solid though and it isn't going anywhere. I think I'm going to add some length to the positive cables though, because right now it has to pass in between the battery and the charge pipes and I don't really like that. I would rather have it come from the right where there is plenty of room.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by harmonator84 &raquo;</TD></TR><TR><TD CLASS="quote">Looks like some crazy rust on that driver door...did you swap doors or patch the rust?</TD></TR></TABLE>I had new sheet metal welded in.
Old Apr 23, 2007 | 06:05 AM
ILcrxsi1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STREETWERKZ &raquo;</TD></TR><TR><TD CLASS="quote">ballin' *** spoolin' ***! </TD></TR></TABLE>you like that huh?
Old Apr 23, 2007 | 07:50 AM
Got_soy's Avatar
have any more pics of tha ballin *** manifold? I'm jealous
Old Apr 23, 2007 | 07:58 AM
ILcrxsi1's Avatar
Default Re: ILcrxsi1's turbo D build(56k, get some lunch) (Got_soy)
If anyone in the chicagoland area can tune Hondata and wants to make some extra money let me know. I was going to go to the whip factory, but economically I don't know if that's going to be possible
Old Apr 23, 2007 | 08:59 AM
89efDUSTY's Avatar
subscribed love the paint job turned out clean
Old Apr 23, 2007 | 09:02 AM
ILcrxsi1's Avatar
Default Re: ILcrxsi1's turbo D build(56k, get some lunch) (89efDUSTY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89efDUSTY &raquo;</TD></TR><TR><TD CLASS="quote">subscribed love the paint job turned out clean </TD></TR></TABLE>Thanks. Yeah the paint came out pretty good, except that under the hood part . It's a maaco job too 2 years now going strong.
Old Apr 23, 2007 | 09:08 AM
89efDUSTY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ILcrxsi1 &raquo;</TD></TR><TR><TD CLASS="quote">Thanks. Yeah the paint came out pretty good, except that under the hood part . It's a maaco job too 2 years now going strong. </TD></TR></TABLE> hahaha nice is it always garaged, and did you prep it yourself?
Old Apr 23, 2007 | 09:17 AM
djphonics's Avatar
Looks good. I'm ready for the ballin' *** manifold and spoolin' *** turbo for sure.
Old Apr 23, 2007 | 09:36 AM
ILcrxsi1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89efDUSTY &raquo;</TD></TR><TR><TD CLASS="quote"> hahaha nice is it always garaged, and did you prep it yourself? </TD></TR></TABLE>It wasn't garage kept until this last december. So it went almost 2 years out in the elements, including snow and ice and all that crap. I didn't prep it myself, but I did pay extra for prep work at maaco.
Old Apr 23, 2007 | 09:45 AM
89efDUSTY's Avatar
if you dont mind me asking approximately how much for the whole job...thanks
Old Apr 23, 2007 | 09:57 AM
ILcrxsi1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89efDUSTY &raquo;</TD></TR><TR><TD CLASS="quote">if you dont mind me asking approximately how much for the whole job...thanks </TD></TR></TABLE>It was like $1200 for rust repair, prep work, good paint, clear coat, door and hatch jams, and I had a bunch of **** painted off the car too, like mouldings, and a brand new sunroof panel. My panel was rusted pretty bad and I didn't want to replace it with another used one that was probably rusting from the inside out so I bought a brand new one.
