Honda S2000 Honda S2000
secondary air pump
Old Apr 22, 2007 | 11:29 AM
regimeteam's Avatar
Default secondary air pump
hello everyone i just had a question. My check engine light went off and when i took it to honda they told me it was a secondary air pump and it has to due with emissions. I was wondering if anyone else had this problem and is it real serious because honda told me it wasn't. If anyone had to change this part how did you go about it honda wants 1100 can i find this part cheaper????????????? Sorry for the length. Thanks s2000 pals
Old Apr 22, 2007 | 02:31 PM
Mr. Projekt's Avatar
* B A N N E D *
Default Re: secondary air pump (regimeteam)
It's not $1100, it's more like $590. I pulled the entire assembly including the fuse, no check engine light.
iam7head's Avatar
is is serious? serious enough to trigger a cel and fail smog test
what exactly was the code? what happen most of the time is some vaccum line is loose and trigger a code. it happen to me once when i did a valve lash adjustment and knockec the check valve loose.
Old Apr 22, 2007 | 04:11 PM
regimeteam's Avatar
Default Re: secondary air pump (iam7head)
the code was like p0004 and it was a secondary pump where would i find a pump like that from
Old Apr 22, 2007 | 04:23 PM
regimeteam's Avatar
Default Re: secondary air pump (Mr. Projekt)
where kind i buy one from and where is it located and is it hard to change
Old Apr 22, 2007 | 05:09 PM
5 Skware's Avatar
I missed the boat
As iam7head replied above...... make absolutly sure that you didn't just knock a vacuume hose loose. It doesn't even have to be totally disconnected just loose or routed improperly. Happens a lot when people install aftermarket intakes. Take a look around and if it is truly broken buy the part and replace it yourself..... it's not that difficult
Old Apr 23, 2007 | 08:14 AM
regimeteam's Avatar
Default Re: secondary air pump (5 Skware)
kool thanks man also where is located ??????
Old Apr 23, 2007 | 08:20 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
front driverside behind the bumper and fender liner.
i had the same code because the clip that holds the plug in place broke... i just plugged it back in and ran some electric tape around that bad boy and never had a issue after that.....
Old Apr 23, 2007 | 10:34 AM
S2000Forsale's Avatar
i had the same issue, the exact code is P0411
Secondary air
Ijection system
Incorrect flow
i got the code pulled by auto zone, checkers, advance parts.. with the same result,, i don't know what to do.
Old Apr 23, 2007 | 05:12 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: (S2000Forsale)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S2000Forsale &raquo;</TD></TR><TR><TD CLASS="quote">i had the same issue, the exact code is P0411
Secondary air
Ijection system
Incorrect flow
i got the code pulled by auto zone, checkers, advance parts.. with the same result,, i don't know what to do.</TD></TR></TABLE>
chekc the vac hose adn make sure its plugged in...
also check the vac lines that run behind the TB they come out sometimes causing the pump CEL to come up
tytex1234
Honda Civic (2001 - 2005)
Sep 12, 2009 11:23 AM
katyruff
Honda S2000
Jul 6, 2008 11:26 AM
ohmigo0lay
Honda S2000
Mar 19, 2007 02:59 PM
sounguy787
Honda S2000
Oct 12, 2006 12:40 PM
kiwirob
Acura TL, RL & ZDX
Jul 5, 2002 10:20 AM
