HELP: HIGH REVING!
Ok i just put a z6 swap into my ef everything is hooked up, im only throwing one code which is the o2 sensor code. when i start my car it seems like someone is holding the gas pedal, it revs really high and doesnt come down, so i shut it off. what could be my problem?
well i kind ahad the same thing.. i just cleaned the IAC and the FITV and it helped a lot
IAC = located on the back fo your intake manifold.
FITV = located under your throttle body
https://honda-tech.com/zerothread?id=1564019
JJARMASEK
Sep 8, 2008 06:35 PM
Ransom
May 14, 2006 03:21 PM
