Lowering Question ( already read the sticky)
Old Apr 22, 2007 | 09:20 AM
loup05's Avatar
Default Lowering Question ( already read the sticky)
ok i have a cd5 and i am looking to lower it. I want to use the eibach sportline springs. I was reading the sticky that i am going to need after market shocks. it also said aftermarket damper ( isnt that the same as shocks? Well anyway my question is can i get some kyb GR2 struts with the sportline springs?
Old Apr 22, 2007 | 09:58 AM
SkimN's Avatar
Default Re: Lowering Question (loup05)
they're the same thing, you can use the gr2's(thats whats on my gf's car), but if you have the money I would get koni's or bilstien but those are $$$
Old Apr 22, 2007 | 10:09 AM
Bruce Banner's Avatar
Default Re: Lowering Question (skimNrace)
damper, strut, shocks, same deal.
At the very least get the kyb agx , if u can koni, if not illuminas
Old Apr 22, 2007 | 11:41 AM
philadd's Avatar
Default Re: Lowering Question (Bruce Banner)
GR2's are an OEM replacement. They're no better than the stock struts.
Old Apr 22, 2007 | 01:01 PM
fw190bvi's Avatar
Default Re: Lowering Question (philadd)
KYB's AGX model shocks
Old Apr 25, 2007 | 01:43 PM
loup05's Avatar
Default Re: Lowering Question (fw190bvi)
i have a couple of Questions. i know my car has struts right now. is there a difference if i get shocks instead of struts (is that even possible)? and again i am for sure gonna get the eibach sportline springs. Do you think i will need an aftermarcket camber kit?
Old Apr 25, 2007 | 02:01 PM
philadd's Avatar
It's not possible to replace a shock with a strut, or vice versa. Let me explain the difference between a strut and a shock.
A shock does one thing: dampen and control the spring's movement.
A strut performs two tasks:
1. dampen the spring's movement, just as a shock does.
2. provide structural support for the vehicle's suspension.
Struts, shocks... don't worry so much about what people call them or label them. Both terms get used at the wrong times.
Old Apr 25, 2007 | 02:34 PM
Loco-B's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by loup05 &raquo;</TD></TR><TR><TD CLASS="quote">i know my car has struts right now.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by loup05 &raquo;</TD></TR><TR><TD CLASS="quote">ok i have a cd5 and i am looking to lower it.</TD></TR></TABLE>
If you have a CD chassis you don't have struts. You have shocks all the way around.
Old Apr 26, 2007 | 02:17 PM
loup05's Avatar
Default Re: Lowering Question (accordcd_7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accordcd_7 &raquo;</TD></TR><TR><TD CLASS="quote">If you have a CD chassis you don't have struts. You have shocks all the way around.</TD></TR></TABLE>
Really i thought that my car was a cd5 according to what i read on the sticky (must have read it wrong) i kno i have struts for sure though.
So do u guys think the drop will cause my camber to be too negative? i dont want to buy new struts, springs, and tires and not have money to buy the camber kit
Old Apr 26, 2007 | 04:10 PM
kleen98accord's Avatar
if you want koni shocks try http://www.shox.com. their products aren't as expensive as others. i got my koni yellows from them. hope it helps.
Old Apr 26, 2007 | 04:44 PM
-RedneckDave-'s Avatar
Working
Default Re: Lowering Question (randomvtec)
Koni yellows is what I have and they are great along with some ground controls.
Old Apr 26, 2007 | 05:30 PM
Loco-B's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by loup05 &raquo;</TD></TR><TR><TD CLASS="quote">So do u guys think the drop will cause my camber to be too negative?</TD></TR></TABLE>
Camber isn't really a problem if you drop your car 2" or less. It's the toe that kills your tires. Always make sure to get alignment after lowering a vehicle.
Old Apr 26, 2007 | 07:13 PM
loup05's Avatar
Camber isn't really a problem if you drop your car 2" or less. It's the toe that kills your tires. Always make sure to get alignment after lowering a vehicle. </TD></TR></TABLE>
Oh thats no big thing. I can align it at the shop i work at. i just wanted to make sure i wasnt going 2 need a camber kit. thanks for the links they are a big help
Old Apr 26, 2007 | 07:15 PM
loup05's Avatar
Default Re: Lowering Question (-RedneckDave-)
i need struts not shocks i didnt see any struts on http://www.shox.com/appguide/s...y.php
93cxhatchsir2
Suspension & Brakes
Aug 9, 2006 01:45 AM
qcktegls
Aug 2, 2004 07:22 PM
YellowGiser
Mar 8, 2004 06:25 AM
integra_dude
Feb 17, 2004 05:50 PM
mini-cRx
Jul 22, 2002 04:31 AM
