Need help with header!!!!
I have a b16 in my crx and I cant get the stock manifold off. It stops at the crossmember and will not go any further....so I tried seperating the header and that wont work either...the 3 bolts are seized pretty damn bad....hit it with a torch for a few minutes, sprayed some wd40 on it....nothing is working....I am using a 14mm wrench on the bolts and I just keep bending the nut and now the 14 mm wont even do anything...
Does anyone have suggestions or anything cause im stuck and I need to get this off ASAP. Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RCautoworks »</TD></TR><TR><TD CLASS="quote">Lower the crossmember</TD></TR></TABLE>
x2.
and if lowering doesnt help, take it out completely
x2.
yeah I just went to sears and got the broken bolt remover thing....took it out with eaze actually......n the middle of cutting up the crossmember right now to get the header in there
