HELP! Car Wont Rev..Bogging...Fule pressure? VAFC "prs" ? please reply
-brief- i have a d16z6 in my 91 ef...running about 2 weeks ago...no CEL...
tranny went up so i pulled the motor...put new tranny and parts on plugged harness in and put back into car...plugged everything in...all fluids...
FIRST START UP- it idles fine at about 1,000rpm , when you go to rev it up...it bogs and wont go past 1,500
FIRST QUESTION-my fuel pressure gauge is at 20psi while car idles, on rev up it jumps around from 40 to 0????
SECOND QUESTION-my vafc 1...at idle "prs" (???what is that???) is in the -400"s, when reving it jumps to around from -300 -200 -100 ?????
MY PROBLEM I THINK - <U>wiring hack job </U>- someone did before i bought the car-
heres a picture the day i pulled it out ...harness untouched and still plugged in...
TPS ??? the grey sensor on back on Thorttle body, i guess the tps has 3 wires coming out of it...
#1 the red wire comes out and is cut ( as shown in black cirle TOP RIGHT)
#2 + 3- run straight over to the yellow plug on left side of intake manifold
SENSOR RUNNING TO ANOTHER SENSOR???? no wires go into harness????
PICTURE-
you can see the wires running back and forth to each other????
HELPPPPPPPPPPPPPPPPPPPPPPPPPPPP!!!!!
HERES A PICTURE OF CUT WIRES IN THE BACK OF MY HARNESS
COULD THIS HAVE AFFECT ON MY CAR NOT REVING AND BOGGING?
DOES TPS CONTROL THAT?
GAS???
VAFC?
HELP PLEASE
PICTURE-
GAS???
VAFC?
HELP PLEASE
I was having the same problem. Check your distibutor. I took my cap off and it looked like a brill-o pad. All the copper wire from the coil was everywhere. Only 2 cylinders were getting enough spark.
BUMP
thanks alot of the answers
the problem is BRAND NEW DISTRIBUTOR
i just got the obd1 conversion harness, p28 and brand new out of box distributor put on by tsr performance....
QUESTION- i had the wrong firing order on first start? did that mess up distributor?
problem fixed
as shown above in the pictures how the " tps grey sensor on back of TB " and the " clean sensor on left hand side of intake manifold " the iacv? whatever those two are...
they ran together before and not into the harness well i color matched some wires together and it worked..
im an idiot
im an idiot
PM-Performance
Sep 3, 2002 09:44 AM
NeXtLeVeL_TyPe_R
Nov 10, 2001 07:11 AM
