Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Moisture In DIY Headlights
Old Apr 22, 2007 | 08:08 AM
TheMoogly's Avatar
Default Moisture In DIY Headlights
Hey guys this is my first post on HT. I DIY blackhoused my factory headlights but they quickly fogged up... without taking the stupid things off my car and resealing them, are there any techniques to drying them while keeping them on the car?
Old Apr 22, 2007 | 08:15 AM
Nodnero's Avatar
Default Re: Moisture In DIY Headlights (TheMoogly)
Turn the headlights on and it will heat up the plastic and help get rid of the fogging. You might be able to find a small hole and blow dry it as well. Either way, without taking the headlights off, there will be water spots from drying and you might not get all of the condensation off of the plastic.
Old Apr 22, 2007 | 08:19 AM
toyomatt84's Avatar
Sanji
Pop a bulb out and squeeze a couple Silica packets in there. They're designed to soak moisture.
Old Apr 22, 2007 | 09:07 AM
Vantage's Avatar
You probably missing a TINY section when u resealed the lights, and therefore let some moisture it. I would try what matt said, but if that fails to work you will probably have to take them apart and redo it
Old Apr 22, 2007 | 10:03 AM
mrtrinh's Avatar
Default Re: (Vantage)
you can drill small holes at the bottom of the headlights... did it on my buddy's integ, works like a charm
Old Apr 22, 2007 | 03:18 PM
theciv's Avatar
Default Re: (mrtrinh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrtrinh &raquo;</TD></TR><TR><TD CLASS="quote">you can drill small holes at the bottom of the headlights... did it on my buddy's integ, works like a charm</TD></TR></TABLE>
yeah, since i'm sure he wants extra holes in his car. haha
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toyomatt84 &raquo;</TD></TR><TR><TD CLASS="quote">Pop a bulb out and squeeze a couple Silica packets in there. They're designed to soak moisture.</TD></TR></TABLE>
agree strongly. works like a carm
Old Apr 22, 2007 | 04:25 PM
Em2 Yo's Avatar
Take the headlights off put them in the oven. They will turn foggy cause all the water is evaorapting and they will turn clear when all the water is gone, thats how you know you have no water or condensation in there, then reseal again and wipe off the excess.
Old Apr 22, 2007 | 05:47 PM
toyomatt84's Avatar
Sanji
Default Re: (Em2 Yo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Em2 Yo &raquo;</TD></TR><TR><TD CLASS="quote">Take the headlights off put them in the oven. They will turn foggy cause all the water is evaorapting and they will turn clear when all the water is gone, thats how you know you have no water or condensation in there, then reseal again and wipe off the excess.</TD></TR></TABLE>
He mentioned that he didn't want to take his headlights off the car.
Old May 13, 2007 | 09:43 AM
EJ8 Kenobi's Avatar
Default Re: (toyomatt84)
hmm does that really work? I never thought of that.
Old May 13, 2007 | 11:01 AM
toyomatt84's Avatar
Sanji
Default Re: (EJ8 Kenobi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ8 Kenobi &raquo;</TD></TR><TR><TD CLASS="quote">
hmm does that really work? I never thought of that.</TD></TR></TABLE>
If you buy some fresh silica packets, it definitely should. Their design is to soak up moisture.
Old May 13, 2007 | 11:07 AM
Curiouz_G's Avatar
they only work for so long though so it isnt a perm. fix
Old May 13, 2007 | 11:25 AM
sujak's Avatar
i had this problem when i had to replace a driver side bulb
fogging went away but left **** all over the inside.
take em apart clean em re-sell em with twice as much silicone as before, works fine
honda_boy23
Mar 14, 2010 09:13 PM
donger
Aug 19, 2008 07:25 PM
cimo463
Apr 2, 2008 01:18 PM
SIcivicHATCH
Jan 13, 2005 05:57 AM
Scartissue
Nov 12, 2004 11:01 AM
