B20 swap wiring/sensors
Old Apr 22, 2007 | 01:43 AM
PDRIFT86's Avatar
Default B20 swap wiring/sensors
Modified by PDRIFT86 at 10:22 PM 4/23/2007
Old Apr 22, 2007 | 09:05 AM
dr_latino999's Avatar
Default Re: B20 swap wiring/sensors (PDRIFT86)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PDRIFT86 &raquo;</TD></TR><TR><TD CLASS="quote">OK, got my b20 mounted in my CRX. now for the fun part. i'm using my si harness da ecu and
an ls intake manifold, witch map sensor should i use?what about all the other sensors? i already re-pinned my obd1 dizzy for obd0. and i bought a civic type-r crank pulley but the alt belt is too big now cuz this pulley is smaller than stock. does any one know which belt i need?
</TD></TR></TABLE>Where do I start?
All MAP sensors are the same (OEM).
You can't use an OBD-1 Distributor with an OBD-0 ECU, electronics are different.
Using a straight B18 computer will not run a B20 optimally.
CTR pulley = ehhhh
Old Apr 22, 2007 | 06:57 PM
PDRIFT86's Avatar
Default Re: B20 swap wiring/sensors (dr_latino999)
Modified by PDRIFT86 at 10:15 PM 4/23/2007
silentdeath12886
Mar 13, 2019 05:40 PM
civic_jason
Dec 7, 2012 07:10 AM
treyh0lla
Jun 28, 2006 09:22 PM
BLUE EH3
Sep 29, 2004 10:53 AM
1SIKCRX
Mar 27, 2004 04:43 PM
