Rear strut bolt is seized
Old Apr 21, 2007 | 09:39 PM
Bird333's Avatar
Default Rear strut bolt is seized
Well, I was in the middle of trying to do my rear disk conversion and the driver's side bolt is seized. I have tried hammering, chiseling, and I broke a c-clamp trying to press the bolt out. These are my options now.
l could cut the bolt. Does anyone know if a Dremel will cut through it? Does dremel make a big enough cutting wheel to do? If not, is there a cutting tool I could buy that would work?
Put everything back together and get a shop to remove it (really would hate to do this to say the least).
Man, it is always something.
Old Apr 21, 2007 | 10:09 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: Rear strut bolt is seized (Bird333)
A hacksaw cuts through bolts fast.
Old Apr 22, 2007 | 07:27 AM
JDM_DC4_Fanatic's Avatar
get a Oxy-acetalene(sp?) torch and heat up the back of the spindel. Then give the bolt a good whack with a big hammer and that should crack the rust loose. Or heat it up to a nice cherry red and spray it with water. That usuially shocks the rust loose.
Old Apr 22, 2007 | 08:44 AM
Twixle's Avatar
ate my pixel
Default Re: Rear strut bolt is seized (JDM_DC4_Fanatic)
Did you try a can of PB breaker and a big breaker bar?
Old Apr 22, 2007 | 03:41 PM
Bird333's Avatar
Default Re: Rear strut bolt is seized (accord2021)
I think I may try heat with a torch and then cold water to break the rust loose. I am just scared I might melt the rubber. Just to be clear I got the nut off of the bolt it's just the bolt is stuck inside the knuckle. How long to you guys usually heat up something to break rust loose?
Old Apr 22, 2007 | 03:46 PM
::MYCORD::'s Avatar
try the can of pb blaster first
Old Apr 22, 2007 | 08:23 PM
Bird333's Avatar
Default Re: Rear strut bolt is seized (::MYCORD::)
I have already done the PB blaster and it didn't do a thing.
Old Apr 22, 2007 | 08:34 PM
lowered94accord's Avatar
have a buddy pull up on the rear hub assembly alot..like up and down really fast and you hammering or pulling on the bolt at the same time..always works for me
stevevang
Mar 27, 2016 04:46 AM
TheHatchHog
10
Jul 29, 2004 07:15 AM
99sonicbluegsr
Mar 1, 2004 07:15 AM
95 Gizzer
Jan 30, 2003 10:26 AM
