timing belt??
Old Apr 21, 2007 | 08:55 PM
mysicivic1991's Avatar
Default timing belt??
when is a good time to change the timing belt?? how do you know if it needs to be change?? pls heelp..
Old Apr 21, 2007 | 08:56 PM
crxnj's Avatar
Default Re: timing belt?? (mysicivic1991)
I like to do it every 80k-90k miles.
Unless it's making noise or you can actually see it shredding,there's no way to tell that it's starting to break,which is why you just do it every XXXX miles..
Old Apr 21, 2007 | 09:06 PM
Default Re: timing belt?? (crxnj)
does it cause the car to lack accleration?? because my car seems to acclerate very slow in a high rpm and it doesnt really move and it kicks in on a high rpm.
Old Apr 21, 2007 | 09:08 PM
crxnj's Avatar
It wouldn't be noticable unless it was off a couple of teeth, causing the timing to be wrong.
What engine do you have?
Old Apr 21, 2007 | 09:09 PM
can it be the clutch is wearing out that makes me acclerate so slow in 1st gear. will a new clutch improve my accerleration at a low rpm and on 1st gear.
Old Apr 21, 2007 | 09:10 PM
crxnj's Avatar
What motor do you have?
Old Apr 21, 2007 | 09:13 PM
its only a d16a6 but its seems like something is holding it back from accelerating in 1st to 2nd but the rest of the gears are fine it actually accerlates quickly.
Old Apr 21, 2007 | 09:21 PM
crxnj's Avatar
What car did you drive before?
Old Apr 21, 2007 | 09:27 PM
i mostly drive this car. i dont really know whats wrong it seems like it got weaker. its has 220k on it. idk..if its the clutch or something else but it seems like im revving it to much and im not really going anywhere.
Old Apr 22, 2007 | 10:14 AM
crxnj's Avatar
Might just need a tune-up
TegraD
Apr 14, 2009 06:38 AM
kadidle
Nov 12, 2007 12:26 PM
kristing1
Aug 16, 2007 10:03 PM
superburner2
Mar 14, 2005 12:39 PM
fastludeh22
Aug 13, 2003 05:41 PM
