i need help (again)
Old Apr 21, 2007 | 07:37 PM
Under Con. CrX's Avatar
Default i need help (again)
hey guys i got my civic running and i noticed it was leaking oil and water
so i changed the head gasket and water pump*188.XXX miles same pump*
and now my cart wont start
now for what i think might be the solution
1.i jumped teeth on timing belt now timing is off*i am a fool i didnt mark the belt so i didnt know where to put it back*
2.water got in my Compresion chamber and my motoro is now seized
now for a nother set of problems my water pump is leaking *yes it has the gasket*
is it possible to put my gasket up side down cus i think i am still leaking oil
thanks guys for any input
Old Apr 21, 2007 | 08:22 PM
Janos Lin's Avatar
Default Re: i need help (Under Con. CrX)
Yes there's a up side on the gasket... I would say your problems are more likely that your head has warped. Take it to a machine shop and have em surface the head back flat. Make sure the finish is shiny, almost like a mirror, should be quite smooth. If it's pretty rough, they didn't surface it correctly.
Did you put hondabond around the water pump and torque it down right?
Janos
Old Apr 21, 2007 | 08:26 PM
Default Re: i need help (Janos Lin)
ok i will have to check the gasket tommorow
as for the bond actuly i didnt where can i get that at??
oh wich is the up side the one with the prints and all the writing??
Old Apr 21, 2007 | 09:48 PM
Old Apr 22, 2007 | 08:27 AM
Janos Lin's Avatar
U can get it from the dealership, or u can buy some permatex gray RTV, it says its for imports and stuff. That stuff works just fine. Make sure everything is clean tho.
Been a while since I looked but the head gasket has part of the top layer that has the words UP stamped out of the metal. If yours is like the soft grey gasket, not some multi-layered metal gasket, send that back and get the multi layered metal one. Once again, get ur head surfaced since thats more likely your problem there.
Janos
raider1qaz
Jan 27, 2013 05:51 PM
honda_ek9
Dec 2, 2010 09:16 AM
nomoreavril
Apr 6, 2008 08:41 PM
TooManyTickets
14
May 27, 2007 03:05 PM
CrazyKoreanCrx
Aug 23, 2004 01:55 PM
