dist.cap and rotor
Old Apr 21, 2007 | 04:19 PM
soon2bdropped's Avatar
Default dist.cap and rotor
replacing dist cap and rotor anybody got any tips on how to do this.. how does this rotor thing work.. does the rotor go inside the shaft?? where does the rotor get power from?
when u turn the dist cap are u turning the shaft.. how doesignition timing work.. does it make it so that the car fires up late or early? if it fires up late it will just crank. if it fires up 2 early... than wouldnt the piston lose power.. wow this is confusing..
Old Apr 21, 2007 | 04:30 PM
Twixle's Avatar
ate my pixel
Default Re: dist.cap and rotor (soon2bdropped)
PM'd
Old Apr 22, 2007 | 06:35 AM
Default Re: dist.cap and rotor (accord2021)
thanks man that help alot.. do you mind telling me where does the rotor get spark from to touch the contact points on the cap.. does the dizzy shaft spin therefore creating sparkage?
Old Apr 22, 2007 | 08:46 AM
Twixle's Avatar
ate my pixel
Correct
Old Apr 22, 2007 | 11:10 AM
so the dizzy shaft has a coil inside so when it spins it creates the sparks than it pass along to the rotor and the rotor spins it on the contact point of the cap?
am i right..
Old Apr 22, 2007 | 12:02 PM
Twixle's Avatar
ate my pixel
http://auto.howstuffworks.com/ignition-system4.htm
You've got the general idea, but the coil on the F22B is external. An arc is created when the shaft passes each of the contact points, send electrical current to spark plug, causing it to spark.
92_EGhatch
Jun 9, 2006 04:16 AM
superhatchbackbros
May 19, 2005 04:54 PM
90civicB16
Dec 3, 2003 09:28 AM
93SSPHatch
May 31, 2002 04:13 AM
absolutgsr
May 28, 2002 11:53 PM
