mini me piston to valve clearence question
has anybody run into any piston to valve clearence issues when doing the mini me swap using a stock bottomend D16a6 with a Z6 head? from what i found doing searches its should be no problem using the stock a6 bottomend with stock z6 cam. what i am concerned about is the clearences when adding an aftermarket cam then adjusting the cam gear.
thanks for you time.
Modified by SCR ZC-T at 4:00 PM 4/21/2007
the bottomend will be stock D16a6. so if i use a z6 head with an aftermarket cam i want to make sure the valves will not hit the pistons. i know can do a piston to valve clearence check using the clay method when i put the head on the block using the stock z6 cam, but i'll be upgrading the cam at a later date and don't want to remove the head just to do the clearence check. i'm just trying to save some time and money, but if i have to do it then oh well it's better then bending valves.
Modified by SCR ZC-T at 4:03 PM 4/21/2007
Steve91
Dec 17, 2004 03:47 AM
jetpilot
Apr 25, 2004 10:05 AM
