H22A Fuel Injector in JDM B16A
I just did an Engine swap with the JDM B16A in my 93 Civic DX. A friend of mine is offering me a set of the Brand new Fuel Injector from a 2000 Prelude, does the fuel injector fit right in? and does it help by any change?
Yup, all you need to use is the correct prelude injector harness. In your case you want to use an OBD-1 harness.
Brian
[Modified by VtecDeMoN, 5:58 AM 5/29/2002]
Brian
which harness does it needed? i thought i just need the injector and bolt it in? pleases help me out , i'm kinda new in this thanx the pix below is my intake manifold and injector which harness do i need ot buy?
[Modified by power_civic, 6:06 AM 5/29/2002]
You're going to need the injectors which already have, as well as an obd-1 prelude injector harness and resistor box, bascially it's what plugs into your injectors, notice the little plugs on top of them. You should be able to find them at a local wrecking yard for pretty inexpensive.
Brian
Brian
89s1
Jul 24, 2004 12:50 AM
opto_isolator
Mar 20, 2004 03:10 PM
