H22A Fuel Injector in JDM B16A
I just did an Engine swap with the JDM B16A in my 93 Civic DX. A friend of mine is offering me a set of the Brand new Fuel Injector from a 2000 Prelude, does the fuel injector fit right in? and does it help by any change?
Re: H22A Fuel Injector in JDM B16A (power_civic)
Yup, all you need to use is the correct prelude injector harness. In your case you want to use an OBD-1 harness.
Brian
[Modified by VtecDeMoN, 5:58 AM 5/29/2002]
Brian
Re: H22A Fuel Injector in JDM B16A (VtecDeMoN)
which harness does it needed? i thought i just need the injector and bolt it in? pleases help me out , i'm kinda new in this thanx the pix below is my intake manifold and injector which harness do i need ot buy?
[Modified by power_civic, 6:06 AM 5/29/2002]
You're going to need the injectors which already have, as well as an obd-1 prelude injector harness and resistor box, bascially it's what plugs into your injectors, notice the little plugs on top of them. You should be able to find them at a local wrecking yard for pretty inexpensive.
Brian
Brian
opto_isolator
03-20-2004 03:10 PM
