change my cct to mcct from ape now oil spitting out of the screw? help
hi guys
well like i said i change my autocct on my 00 gsxr 600 to manual cct from ape and drove it for a week and its fine now whn i check its spitting out oil all over the starter on top of the tranny crank case cover down to my fairings how can i patch the leak i mean i tried to loosen the screw that hold the mcct and no luck pls help i hate oil leak and the mess thanks in advance
Did you use a gasket with the manual cam chain tensioner when you first installed it and did you tension it properly by opening up the head and looking inside or did you simply remove the auto cct and install the manual one because then you might run into problems with oil leaking out or worse engine failure and then you would be in some serious trouble but hey why don't you try putting in punctuation next time in your post.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by marmaladeboy »</TD></TR><TR><TD CLASS="quote">Did you use a gasket with the manual cam chain tensioner when you first installed it and did you tension it properly by opening up the head and looking inside or did you simply remove the auto cct and install the manual one because then you might run into problems with oil leaking out or worse engine failure and then you would be in some serious trouble but hey why don't you try putting in punctuation next time in your post.</TD></TR></TABLE>
yes i did use a ape new gasket and yes i open the head and check the slack of the chain and like i said the oil leak is coming out of the lower left screw of the manual cct and the one in the middle wnd thats weird cuz i never heared about leaking oil in that middle screw and now i think i over torque the lower left screw now i cant take it off to put some silicone a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onepointsixvtecturbo »</TD></TR><TR><TD CLASS="quote">yes i did use a ape new gasket and yes i open the head and check the slack of the chain and like i said the oil leak is coming out of the lower left screw of the manual cct and the one in the middle wnd thats weird cuz i never heared about leaking oil in that middle screw and now i think i over torque the lower left screw now i cant take it off to put some silicone a
it's called puncuation and it makes sentences a hell of alot easier to read.
</TD></TR></TABLE>it's called puncuation and it makes sentences a hell of alot easier to read.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rdblckSV650S »</TD></TR><TR><TD CLASS="quote">
it's called puncuation and it makes sentences a hell of alot easier to read.</TD></TR></TABLE>
read his sig LOL
read his sig LOL
01PYTypeR#1140
Oct 7, 2003 05:40 AM
