i have seen 'palm sander' in several threads here:
Old Apr 21, 2007 | 11:18 AM
chris_c's Avatar
Default i have seen 'palm sander' in several threads here:
sanding blocks > palm sander.
i have a DA but i did all the bodywork and sanding on my corvette w/ sanding blocks. durablock > all.
this is fact.
if you are just getting started pick these up as opposed to a electric orbital sander or a DA the runs off your compressor.
http://www2.northerntool.com/p...7.htm
nothing but sanding blocks used on that car...
Old Apr 21, 2007 | 11:47 AM
TodaCivic's Avatar
Default Re: i have seen 'palm sander' in several threads here: (chris c)
I don't really like sanding blocks, i used to always use thick paint paddles wrapped in sandpaper... for dry or wet sanding.
It's all about what makes you comfortable doing the job... but for finishing sanding a d/a sander is a bad idea, blocksanding is called that for a reason.
Old Apr 21, 2007 | 01:12 PM
John M's Avatar
Default Re: i have seen 'palm sander' in several threads here: (TodaCivic)
yes block>palm
Old Apr 22, 2007 | 05:49 AM
swappedcx's Avatar
Default Re: i have seen 'palm sander' in several threads here: (John M)
you know except for when you suck at spraying clear (not me...just saying about others I know) and you get mad orange peel...yea its alot easier to use 3M's scuffing and buffing system on the DA than to block wet sand the entire car or panel. Goes alot quicker when you can just 1500 grit DA, 3000 grit wet DA...then go right to buff.
Old Apr 22, 2007 | 08:12 AM
chris_c's Avatar
Default Re: i have seen 'palm sander' in several threads here: (swappedcx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by swappedcx &raquo;</TD></TR><TR><TD CLASS="quote">you know except for when you suck at spraying clear (not me...just saying about others I know) and you get mad orange peel...yea its alot easier to use 3M's scuffing and buffing system on the DA than to block wet sand the entire car or panel. Goes alot quicker when you can just 1500 grit DA, 3000 grit wet DA...then go right to buff.</TD></TR></TABLE>
i'd say it really depends upon the shape of the body panels. i am a firm believer that you can get a straighter finish wet sanding by hand vs DA. it is very time consuming but worth it imo...
Old Apr 22, 2007 | 03:42 PM
phatboycrxhf's Avatar
ive noticed this allso ,a palm sander is not a block sander ,this is going to mix people up when going to buy there first set of auto body stuff ,i have all the dura block block sanders and i live by them in my oppinon ,just useing a da or orbital sander ,your going to be left with waves in the work ,thats why you block after.
and you dont just get orange peel from your clear,you can allso have nasty orange peel in your paint if its not mixed right
Old Apr 22, 2007 | 05:33 PM
swappedcx's Avatar
Default Re: i have seen 'palm sander' in several threads here: (phatboycrxhf)
First, you should NEVER use a DA for sanding filler unless feather edging it. And what do you mean orange peel from not mixing your paint right? Theres only two ways to mix your paint. Either its right or its wrong. If your talking about how much reducer you put in...then yes...and also gun setup. The majority of orange peel is in the clear. You have to totally be a noob if your getting orange peel bad in the base.
Old Apr 27, 2007 | 02:26 PM
mztykal's Avatar
You can't peel base. That's super hard to do.
I swear by Durablocks. I have a drawer full of em and I'm probably gonna be buying more. They're awesome!
Old Apr 27, 2007 | 11:23 PM
EKFerioHawaii's Avatar
Default Re: i have seen 'palm sander' in several threads here: (mztykal)
durablocks gotz my vote~
But I agree with the guy before, I only tend to use palm DA orbitals for feathering.
Urethane peel sucks.
Old Apr 28, 2007 | 09:04 PM
NuRon's Avatar
chris, I wanted to purchase a set on eBay and save 10 bucks but your link comes with a bar of soap, do I need that haha. So I just wrap different grits of sandpaper around the blocks and do all my work with it?
Old Apr 29, 2007 | 09:31 AM
chris_c's Avatar
Default Re: (NuRon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NuRon &raquo;</TD></TR><TR><TD CLASS="quote">chris, I wanted to purchase a set on eBay and save 10 bucks but your link comes with a bar of soap, do I need that haha. So I just wrap different grits of sandpaper around the blocks and do all my work with it?</TD></TR></TABLE>
i buy rolls of paper. they have adheasive on the back and stick to the block.
finer grit i buy as sheets and just wrap the block.
you might wanna search online as i didn't look for the cheapest link i just searched for durablock and posted the first link....
Old Apr 29, 2007 | 06:39 PM
91ed9's Avatar
Default Re: (chris c)
durablock FTW
i dont think i ever used an orbital sander when i did my car
i just rapped sandpaper around the block
i jsut got the packets of liek 4 sheets of sandpaper its cheaper than buyign the ones with sticky;s on the backside
Old Apr 30, 2007 | 11:37 AM
harmonator84's Avatar
Default Re: (91ed9)
If you are inexperianced then you dont want to use a palm sander....Back in school our teacher would never let us use one. So I got kinda used to always using my hand to sand.
Old Apr 30, 2007 | 01:01 PM
dinko's Avatar
Default Re: (harmonator)
I'm at work right now otherwise I'd post pics of the sides of my car and why you SHOULDN'T EVER use a DA sander to do "finish" type work...that's why i'm gonna be redoing my quarter panels and doors with block and board sanders.
i was a n00b though. interior came out pretty good though...
ken9
Paint and Body
Feb 22, 2009 08:41 AM
DFW
Paint and Body
20
Oct 29, 2008 11:13 AM
Killtodie
Honda Civic (2001 - 2005)
Jun 4, 2007 04:51 PM
drunknbass
Jun 6, 2004 09:03 PM
ShadowRSX
Oct 23, 2001 08:10 PM
