Painting small areas
Old Apr 21, 2007 | 10:36 AM
NuRon's Avatar
Default Painting small areas
Hey guys, I'd like to ask some stuff about painting my car. I was thinking of buying a palm sander, body filler, primer, sand paper, and a spray can of my car's paint mixed at a store. Should that be all I need? What kinda grit sandpaper in stages should I be using? Thanks!
Old Apr 21, 2007 | 11:11 AM
chris_c's Avatar
Default Re: Painting small areas (NuRon)
describe your small areas...
you don't need a palm sander and you'd be much better off spending that money on a set of sanding blocks.
sand the painted area w/ 400 but don't remove the paint on the good areas, just scuff the clear. sand the damaged areas w/ 220 and do you body work. shape w/ the sanding blocks using 220, 320. if needed use more aggressive paper to get close. spray a sealer, spray your base coat over the body work. clear panel.
Old Apr 21, 2007 | 12:02 PM
NuRon's Avatar
Default Re: Painting small areas (chris c)
Thanks for the reply, these are the areas I'm talking about:
Rear window
Rear passenger door
Dulling paint
Door
Other rear door
Old Apr 21, 2007 | 01:11 PM
John M's Avatar
Dude i say just primer your car and get a new paintjob
Old Apr 21, 2007 | 01:48 PM
NuRon's Avatar
It's not worth it man, it's an '88 Camry. I was thinking of trying to learn how to do some body work through this little project.
Old Apr 21, 2007 | 02:13 PM
John M's Avatar
Default Re: (NuRon)
$50 paint job thread ftw
Old Apr 21, 2007 | 03:30 PM
vltnolia's Avatar
88 camry? Save your time.
Old Apr 21, 2007 | 11:31 PM
NuRon's Avatar
I want some practice on it. Rather this than a car that's worth something.
Old Apr 22, 2007 | 02:53 AM
JJ's civic's Avatar
Default Re: (NuRon)
you' do have a point. might as well practice on a car you don't care how it comes out. instead of on a car you want to be perfect. once i getting ready to do the body work on my civic i'm going to bring my truck into the garage and proctice on it. and it's not if legal for the road lol.
Old Apr 22, 2007 | 09:31 PM
dude_123's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NuRon &raquo;</TD></TR><TR><TD CLASS="quote">
Hey guys, I'd like to ask some stuff about painting my car. I was thinking of buying a palm sander, body filler, primer, sand paper, and a spray can of my car's paint mixed at a store. Should that be all I need? What kinda grit sandpaper in stages should I be using? Thanks!</TD></TR></TABLE>
Add metal prep (to stop rust, rust is like cancer), airplane stripper (to take off dull/dead/cracking paint), primer surfacer (to build up the substrate), and epoxy primer (seal/and promote better adhesion for paint to stick on) to your list. Practice correctly and you will be a better autobody tech.
Old Apr 23, 2007 | 03:06 PM
NuRon's Avatar
I'm trying to do like the top half portion of the door only though, could I brush on the airplane stripper while taping the rest off?
Diyracing2
Paint and Body
Oct 17, 2007 10:45 PM
t0p_sh0tta
Paint and Body
May 29, 2007 06:16 AM
stiness101
Apr 25, 2006 05:06 PM
RacerBoy
Jan 13, 2003 08:24 PM
Unjockable
Oct 8, 2001 09:38 AM
