Has Anyone Done a Rear Disc Conversion?
has anyone done a rear disc conversion on a crx? integra rear disc brakes onto a crx with drums? if so, what did you do, do you have to connect hoses, or does it just bolt up? if you have pics, can you post them?
Hoses as in brake lines? Yes.
It is vary easy and straightforward.
If you only change the trailing arm you dont need a alignment but if you replace all the arms you will.
holy shizzzzznitttiy i think someone has, i found this in the FAQ
https://honda-tech.com/zerothread/1916212
Being that you have ask a ton of questions lately you need to read this https://honda-tech.com/zerothread/1508680
importfan7
Mar 24, 2006 09:55 AM
lkist013
Jan 12, 2006 05:30 PM
