Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
06 ex::no second gear??
Old Apr 20, 2007 | 11:25 PM
ekcoupe88's Avatar
Default 06 ex::no second gear??
couple of days ago, he was just crusing, everyday driving, and he went to put it into second gear... grinded like hell, and he tried to put it back in, (babying it) and same thing, so he just went to third.after this, he tried to take off from second verrry slowley, and just grinded and no second... stayed like this for a a couple days, and today, he happened to try his second, to see how it would react, and it went in problem solved... yet now, his second gear is verry hard, and its hard to take it out of gear... anyone have any ideas? i say shift linkage... ??
Old Apr 20, 2007 | 11:30 PM
FBPSidan's Avatar
Default Re: 06 ex::no second gear?? (ekcoupe88)
i say take it to the dealer!
Old Apr 20, 2007 | 11:32 PM
ekcoupe88's Avatar
yea he already has an appointment for tuesday, and its still under warrenty, but just curious as to any solutions.. cause its driving us crazy
Old Apr 21, 2007 | 12:23 PM
spammy123's Avatar
the same exact thing happened to me. the reason its doing that is because second gear is chewed up and all the 2nd gear internals are probably out of whack. i took mine to honda wen this happened less than 2 months of owning the car. they claimed it was from abuse. they brought in a specialist to cover their *** and prove it wasnt manufacturer default. they also said it would not be covered at all next time it happened. i thought it was bs but at least they fixed it under warranty.
Old Apr 22, 2007 | 07:06 AM
R18A1FG's Avatar
Default Re: (spammy123)
Happened in my EP3, luckily I was working for honda then as I am now. Mine was shift forks though, It would get stuck in 2nd and grind like hell until I got it out.
Recently We have seen a couple in with problems in 2nd or 3rd, (seems skipping gears is taking a toll on these trannys), I have always made sure to hit every gear (sequentially, as designed). I guess a lot of people dont and it is tearing the hell outta the synchros!
Old Apr 22, 2007 | 02:47 PM
spammy123's Avatar
i wasnt skipping gears in mine, i was definatly popping it into second sometimes tho. i guess the gears couldnt handle powershifting.
Old Apr 22, 2007 | 03:12 PM
eL's Avatar
eL
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekcoupe88 &raquo;</TD></TR><TR><TD CLASS="quote"> i say shift linkage... ?? </TD></TR></TABLE>
...shift linkage? on an FG? probably not
Old Apr 22, 2007 | 04:50 PM
spammy123's Avatar
i guess what they did to fix mine was replace second gear itself. along with all the internals directly related to 2nd
Old Apr 22, 2007 | 05:57 PM
ekcoupe88's Avatar
hmm... i duno, but thats exactly what we figure they`ll say... that its from abuse... but up to now, its still doing it... like it works and all, but its suppper stiff getting out of second... hopefully theyll cover it...
Old Apr 23, 2007 | 10:39 AM
fuhsm1's Avatar
Default Re: (R18A1FG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R18A1FG &raquo;</TD></TR><TR><TD CLASS="quote">Recently We have seen a couple in with problems in 2nd or 3rd, (seems skipping gears is taking a toll on these trannys), I have always made sure to hit every gear (sequentially, as designed). I guess a lot of people dont and it is tearing the hell outta the synchros! </TD></TR></TABLE>
I have a 2006 Civic Ex, and there are times when I need to get up to speed quickly through the first couple of gears, then once I'm up to highway speed, I might skip from 2nd to 4th, or 3rd to 5th, or whatever. I don't really do it that often, maybe once a week (and I drive ~80 miles a day).
Skipping gears like that will legitimately wear down the synchros? I'm not saying you're wrong, I just never heard of that before. If it is, then I'll use every gear sequentially like it was designed
Old Apr 23, 2007 | 10:40 AM
eL's Avatar
eL
I don't see why skipping gears would be a problem.
Old Apr 23, 2007 | 11:28 AM
fuhsm1's Avatar
Default Re: (eL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eL &raquo;</TD></TR><TR><TD CLASS="quote">I don't see why skipping gears would be a problem.</TD></TR></TABLE>
Neither do I, maybe R18A1FG has some more info to help explain...
Old Apr 23, 2007 | 11:33 AM
WILD_WILL's Avatar
Default Re: (eL)
The way i see it is why even skip gears its not hard or much effort to go from 2cd to 3rd to 4th to 5th to 6th while getting and on the highway if its gonna mess up the tranny why do it at all ive never even thought about doing that.
Old Apr 23, 2007 | 01:28 PM
japspecjohn's Avatar
Default Re: (WILD_WILL)
I never heard that you cant skip gears news to me....I know some cars like the late model camaro z28s and ss's are set so you have to skip gears when just driving regularly...I know I know totally diff car but ayy..Ive been skipping gears in all 12 or so hondas Ive owned and never had a tranny go on me or a prob I figure if Im up to speed already might as well throw in 6th or 5th....but for the most part I go through them all
Old Apr 23, 2007 | 02:47 PM
SMoLiK's Avatar
I dont see why skipping gears would cause a problem, the syncro does not care what gear you just came from all it cares about is the RPM's of the engine... That is why we dont have to double clutch our cars like the old muscle cars, we HAVE synchros...
Power shifting can cause problems.
SMo'
Old Apr 26, 2007 | 05:47 AM
ekcoupe88's Avatar
okayy, so my friend took his ex to honda, and they checked it out, in less then 3 hours he got a call baq, and supposedly everything is fine... all they did was lubricate everything, and told him, if it happens again, to bring it baq...
Old Apr 26, 2007 | 09:05 AM
redcivic06's Avatar
Default Re: (ekcoupe88)
not 3 hours more like a day and a half to be exact....
Patrick Brown
Classic Hondas
Apr 23, 2019 11:25 PM
norcalB18
Transmission & Drivetrain
Sep 28, 2017 02:39 AM
Kevykev
Acura TSX
Jul 13, 2008 09:33 AM
b20civic
Sep 8, 2002 11:33 PM
onyx00
Jul 26, 2002 06:57 PM
