what hoses to remove or bypass throttle body coolant lines i wanna keep my throttle body c0older
Old Apr 20, 2007 | 07:22 PM
dougshatch's Avatar
Default what hoses to remove or bypass throttle body coolant lines i wanna keep my throttle body c0older
i have a 91 Honda crx SI i wanna know what c0olant lines do i take off.....what do i do with them block them off or like bypass them.....and what hoses should i take off there are like 2 in the back and 2 in the front of the intake manifold does anyone know any links or have any pictures on which ones to take out
Old Apr 20, 2007 | 07:26 PM
abnaasefmb's Avatar
Default Re: what hoses to remove or bypass throttle body coolant lines i wanna keep my throttle body c0older
and why do you want to do this?
Old Apr 20, 2007 | 07:31 PM
brandoom's Avatar
An Hero
Taking out the coolant lines make your throttle body cooler?
Stupid honda.
Old Apr 20, 2007 | 07:36 PM
abnaasefmb's Avatar
oh yeah, i forgot!
Old Apr 20, 2007 | 07:44 PM
aarontrini85's Avatar
show me proof that this actual helps enough to make it worth the 10 min it takes
and being in NJ it gets cold so i think you might want to keep them on to try and help the butterfly on the TB from sticking
Old Apr 21, 2007 | 08:41 AM
dougshatch's Avatar
cause it keeps the intake manifold colder and hot fukin antifreeze goin threw it keeps it hot so i want to disconnect the hoses goin to it so does any one know which ones to disconnect
Old Apr 21, 2007 | 08:42 AM
dougshatch's Avatar
im not really worried about the butterfly stickin why do you are all i asked for is help on which hoses to disconnect not all the comments
Old Apr 21, 2007 | 08:52 AM
SIred91's Avatar
Rainman
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dougshatch &raquo;</TD></TR><TR><TD CLASS="quote">im not really worried about the butterfly stickin why do you are all i asked for is help on which hoses to disconnect not all the comments</TD></TR></TABLE>
Why? Because you are asking for help to do something that in NO way will give you any kind of performance gain whatsoever.
None.
Old Apr 21, 2007 | 09:07 AM
dougshatch's Avatar
Old Apr 21, 2007 | 09:08 AM
dougshatch's Avatar
do you know how to do it
Old Apr 21, 2007 | 09:12 AM
janz3n's Avatar
aaaaaaaaahahaha.. why dont you remove the lines that go to the damn TB.. sounds easy enough to me. i think theres two.. block them off an the TB and the intake manifold and your set. seems prettty common sense to me
but i wouldnt do it.
Old Apr 21, 2007 | 09:29 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by janz3n &raquo;</TD></TR><TR><TD CLASS="quote">aaaaaaaaahahaha.. why dont you remove the lines that go to the damn TB.. sounds easy enough to me. i think theres two.. block them off an the TB and the intake manifold and your set. seems prettty common sense to me
but i wouldnt do it.</TD></TR></TABLE>
exactly lol its simple as expletive to figgure out if you just look at the t/b
Old Apr 21, 2007 | 11:39 AM
abnaasefmb's Avatar
It is simple, just detrimental. Just remember how they were hooked up and keep the lines so when you get tired of your car idling shitty you can return it to stock. Take the line coming out of the rear coolant tube and route it to the head. Or just cap them off. good luck and let us know how much this drops you ET.
Old Apr 21, 2007 | 11:43 AM
abnaasefmb's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIred91 &raquo;</TD></TR><TR><TD CLASS="quote">
None.</TD></TR></TABLE>
I love how the only pearl of wisdom in this whole thread gets totally disregarded. Lo,l nice try Sired91 now fu&lt;k off and spew you knowledge elsewhere lol!!!!!!!!!!!
Old Apr 22, 2007 | 04:52 PM
dougshatch's Avatar
aaaaaaaaaahahahah cause when i did that and blocked off the 2 lines that g0o to the TB they built up alot of pressure aahahah dumb *** thats why im asking for a little help and some common sense from other people
Old Apr 22, 2007 | 04:59 PM
dumb *** dont block them one feeds in the other is a return so connect them together and bypass the t/b
Old Apr 22, 2007 | 05:38 PM
gibsanez's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dougshatch &raquo;</TD></TR><TR><TD CLASS="quote"> aaaaaaaaaahahahah cause when i did that and blocked off the 2 lines that g0o to the TB they built up alot of pressure aahahah dumb *** thats why im asking for a little help and some common sense from other people</TD></TR></TABLE>
Try listening for once and consider that this will in no way help your engine out, at all. This reminds me of the thread about the kid that wanted to run an intercooler as an intake.
Old Apr 22, 2007 | 05:49 PM
abnaasefmb's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by abnaasefmb &raquo;</TD></TR><TR><TD CLASS="quote">Take the line coming out of the rear coolant tube and route it to the head. good luck and let us know how much this drops you ET. </TD></TR></TABLE>
Old Apr 22, 2007 | 05:53 PM
brandoom's Avatar
An Hero
My header gets pretty hot when i drive my car for awhile.
Anyone know how i can take that **** out?
Old Apr 22, 2007 | 05:58 PM
abnaasefmb's Avatar
Disconnect header, remove flammable things from the engine bay, get some hearing protection. Let us know it turns out.
Old Apr 22, 2007 | 07:17 PM
brandoom's Avatar
An Hero
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by abnaasefmb &raquo;</TD></TR><TR><TD CLASS="quote">remove flammable things from the engine bay, </TD></TR></TABLE>
I already took out the fuel rail.
Brake fluid is next.
Where can i buy some Ear muffs, i searched, i cant find any in the for sale wtb thread...
anyone help?
Old Apr 22, 2007 | 07:34 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brandoom &raquo;</TD></TR><TR><TD CLASS="quote">
anyone help?</TD></TR></TABLE>
here you go some mad tyte jdm ear muffs
http://cgi.ebay.co.uk/HELLO-KI...wItem
they will help performance as much as bypassing the coolant flow through the t/b and your heat reducing mod
Old Apr 22, 2007 | 07:36 PM
brandoom's Avatar
An Hero
Those earmuffs are ok. But im looking for some with wings on the sides.
You know, for aerodynamic purposes.
Old Apr 22, 2007 | 07:43 PM
abnaasefmb's Avatar
I can see where this is going. So fu&lt;k it, hire a Porto Rican midget in a flame retardant suit and a spray bottle of gas to live under you hood and every time you want to accelerate yell vomanos! And he’ll squirt fuel in the engine while opening up the tb.
Old Apr 22, 2007 | 08:09 PM
brandoom's Avatar
An Hero
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by abnaasefmb &raquo;</TD></TR><TR><TD CLASS="quote">every time you want to accelerate yell vomanos! And he’ll squirt fuel in the engine while opening up the tb.</TD></TR></TABLE>
If that isnt cig worthy, nothing is....
But im worried about the wieght of a puerto rican midget.
I might get a JDM one. ?
